No agitation
The washer fills, spins, but will not agitate. When in that cycle, the motor smells hot. The washer is located in a heated basement. I cannot spin the agitator by hand, but it does spin during the spin cycle.
Remove the front panel by removing the two screws at the bottom of the front panel and swinging the front panel out from the bottom to disengage the spring fasteners from the top cover.
Remove the belts and inspect them. Turn the large drive pulley by hand CCW (looking at it from the bottom). If the pulley will not turn, the transmission has to be replaced. Post the results. Here are the breakdown diagrams and Replacement parts for MAYTAG LAT8404AAE WASHER-TOP LOADING | AppliancePartsPros.com Gene. |
| All times are GMT -7. The time now is 06:04 AM. |
