| » Washer will not fill or Agitate |
Model Number: LSR9434PT4 Brand: Whirlpool Age: 5 - 10 years
Washer will not fill or Agitate. Only spins and sprays water. Checked water level switch and switch works. Water Valve will not fill.
Whirpool washer LSR9434PT4 Ads By Google Related Models |
Quote:
Based on your post, You need to check the hot water fill valve solenoid for resistance and or 120 volts at the fill valve in a hot wash fill setting. That will tell us if the temperaure switch and the timer are working correctly. Have you tried starting the washer on a cold wash, cold rinse or warm wash,cold rinse setting ? That will give us a better idea of what's wrong.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Since you have a new timer, we can bypass that for now. Did you check for the 120 VAC at the fill valve solenoid(s) in a fill setting ? Tan/Black to White on the solenoid wires,in a Hot fill, should have 120 VAC Yellow/Red to white on the solenoid wires, in a cold fill should have 120 VAC If you have the voltage, replace the fill valve, Part number: AP3094541 At the water level switch: Check Purple to chassis ground for 120 VAC, Check Pink to chassis ground for 120 VAC, No 120 VAC on Purple, Bad Lid switch or wire, No 120 VAC on Pink, bad water level switch. Part number: AP3180933 Part number: AP4567828 *** These are "live" voltage checks, so be CAREFUL ***
__________________
Quote:
Found Water level switch was shorted. Points inside burnt completely off causing a floating piece of metal debris. BTW: Thank you for your help. |
Quote:
Great job, A broken contact, is not an everyday occurrence,they usually fail when they arc together, or worp out of shape, where they won't close. We were happy to help, Glad you're up and running, Thanks Again,
__________________
| Display Modes | |
| Washer-OK Fill/NO Spin or Agitate | dperry | Washer Repair | 1 | 09-06-2010 06:58 PM |
| Washer will fill and agitate, then stop | tjshan68 | Washer Repair | 3 | 10-21-2009 03:55 AM |
| Washer will fill but won't spin or agitate | iowaguy | Washer Repair | 1 | 09-21-2009 10:32 AM |
| washer will fill up but will not agitate or drain | jetman | Washer Repair | 1 | 05-12-2009 02:06 PM |
| whirlpool washer does not fill but does agitate | lambert | Washer Repair | 1 | 01-24-2008 05:04 PM |
