Discuss
Maytag Washer Drain Pump Leaking
 in
Washer Repair
Today I did a load of laundry and discovered afterwards that about a quart or two of water had leaked
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Washer Drain Pump Leaking
  #1 (permalink)
Old 02-02-2011, 03:02 PM
Junior Member
Divelucaya is on a distinguished road
Default Maytag Washer Drain Pump Leaking
Model Number: LAT9200BAE   Brand: Maytag   Age: More than 10 years
Today I did a load of laundry and discovered afterwards that about a quart or two of water had leaked on the floor. I checked water hose connections and saw no leakage. I started a 2nd load and water began running out from under the washer as the tub filled. I put my hand under the drain pump area and felt the water leaking out steadily. There's no water in the base of the washer so water seems to be leaking along shaft. I thought maybe there was some shaft packing that had dried out (about 3 weeks since washer last used) but figured the leak would have been just as bad during the 1st load.
Any ideas what the problem may be? Is there any repairs or adjustments that can be made to the pump or is it just time for a new one? There have been a several times in the past that there was some very minor leakage and a couple times it seemed to be because of a sock in the pump that I have had to pull out.
Related Models
Maytag LAT9200BAE WASHER-TOP LOADING
Maytag LAT9200BAL WASHER-TOP LOADING
Maytag LAT9200BAM WASHER-TOP LOADING
Maytag LAT9200BAW WASHER-TOP LOADING
Maytag LAT9200BBE WASHER-TOP LOADING
Maytag LAT9200BBL WASHER-TOP LOADING
Maytag LAT9200BBM WASHER-TOP LOADING
Maytag LAT9200BBW WASHER-TOP LOADING
Maytag LAT9200DAL WASHER-TOP LOADING
Maytag LAT9200DAW WASHER-TOP LOADING
Maytag LAT9205AAE WASHER-TOP LOADING
Maytag LAT9205AAM WASHER-TOP LOADING
Admiral LAT9205GGE WASHER-TOP LOADING
Maytag LAT9206AAE WASHER-TOP LOADING
Maytag LAT9206AAM WASHER-TOP LOADING
Maytag LAT9206ABE WASHER-TOP LOADING
Maytag LAT9206ABM WASHER-TOP LOADING
Maytag LAT9206BAE WASHER-TOP LOADING
Maytag LAT9206BAM WASHER-TOP LOADING
Maytag LAT9206BAQ WASHER-TOP LOADING
Maytag LAT9206BBE WASHER-TOP LOADING
Maytag LAT9206BBM WASHER-TOP LOADING
Maytag LAT9235AAE WASHER-TOP LOADING
Maytag LAT9235AAM WASHER-TOP LOADING
Maytag LAT9280AAL WASHER-TOP LOADING
Maytag LAT9280AAW WASHER-TOP LOADING
Maytag LAT9280ABL WASHER-TOP LOADING
Maytag LAT9280ABW WASHER-TOP LOADING
Maytag LAT9300AAL WASHER-TOP LOADING
Maytag LAT9300AAW WASHER-TOP LOADING
Maytag LAT9300ABL WASHER-TOP LOADING
Maytag LAT9300ABW WASHER-TOP LOADING
Maytag LAT9304AAE WASHER-TOP LOADING
Maytag LAT9304AAL WASHER-TOP LOADING
Maytag LAT9304AAM WASHER-TOP LOADING
Maytag LAT9304ABE WASHER-TOP LOADING
Admiral LAT9304AGE WASHER-TOP LOADING
Admiral LAT9304AGL WASHER-TOP LOADING
Admiral LAT9304AGM WASHER-TOP LOADING
Admiral LAT9304BGE WASHER-TOP LOADING
Maytag LAT9304DAL WASHER-TOP LOADING
Maytag LAT9304DAM WASHER-TOP LOADING
Admiral LAT9304EGE WASHER-TOP LOADING
Admiral LAT9304GGE WASHER-TOP LOADING
Maytag LAT9306AAE WASHER-TOP LOADING
Maytag LAT9306AAM WASHER-TOP LOADING
Maytag LAT9306ABE WASHER-TOP LOADING
Admiral LAT9306AGE WASHER-TOP LOADING
Admiral LAT9306AKM WASHER-TOP LOADING
Admiral LAT9306AKQ WASHER-TOP LOADING
Admiral LAT9306BGE WASHER-TOP LOADING
Admiral LAT9306DAM WASHER-TOP LOADING
Admiral LAT9306DAQ WASHER-TOP LOADING
Admiral LAT9306EGE WASHER-TOP LOADING
Admiral LAT9306GGE WASHER-TOP LOADING
Maytag LAT9314AAE WASHER-TOP LOADING
Maytag LAT9314AAL WASHER-TOP LOADING
Maytag LAT9314AAM WASHER-TOP LOADING
Maytag LAT9314ABE WASHER-TOP LOADING
Maytag LAT9316AAE WASHER-TOP LOADING
Maytag LAT9316AAM WASHER-TOP LOADING
Maytag LAT9316ABE WASHER-TOP LOADING
Maytag LAT9316ABM WASHER-TOP LOADING
Maytag LAT9334AAE WASHER-TOP LOADING
Maytag LAT9334AAL WASHER-TOP LOADING
Maytag LAT9334AAM WASHER-TOP LOADING
Maytag LAT9334ABE WASHER-TOP LOADING
Maytag LAT9356AAE WASHER-TOP LOADING
Maytag LAT9356AAM WASHER-TOP LOADING
Maytag LAT9356AAQ WASHER-TOP LOADING
Maytag LAT9356ABE WASHER-TOP LOADING
Maytag LAT9356ABM WASHER-TOP LOADING
Maytag LAT9357AAE WASHER-TOP LOADING
Maytag LAT9357AAM WASHER-TOP LOADING
Maytag LAT9357AAQ WASHER-TOP LOADING
Maytag LAT9360AAE WASHER-TOP LOADING
Maytag LAT9390AAE WASHER-TOP LOADING
Maytag LAT9400AAE WASHER-TOP LOADING
Maytag LAT9400AAL WASHER-TOP LOADING
Maytag LAT9400AAW WASHER-TOP LOADING
Maytag LAT9400ABE WASHER-TOP LOADING
Maytag LAT9400ABL WASHER-TOP LOADING
Maytag LAT9400ABW WASHER-TOP LOADING
Maytag LAT9400AGL WASHER-TOP LOADING
Maytag LAT9400AGW WASHER-TOP LOADING
Maytag LAT9400DAL WASHER-TOP LOADING
Maytag LAT9400DAW WASHER-TOP LOADING
Maytag LAT9406AAE WASHER-TOP LOADING
Maytag LAT9406AAM WASHER-TOP LOADING
Maytag LAT9406ABE WASHER-TOP LOADING
Maytag LAT9416AAE WASHER-TOP LOADING
Maytag LAT9416AAM WASHER-TOP LOADING
Maytag LAT9416AAQ WASHER-TOP LOADING
Maytag LAT9420AAE WASHER-TOP LOADING
Maytag LAT9457AAE WASHER-TOP LOADING
Maytag LAT9457AAM WASHER-TOP LOADING
Maytag LAT9457AAQ WASHER-TOP LOADING
Maytag LAT9457BAE WASHER-TOP LOADING
Maytag LAT9520AAE WASHER-TOP LOADING
Maytag LAT9520AAQ WASHER-TOP LOADING
Maytag LAT9557AAE WASHER-TOP LOADING
Maytag LAT9557AAQ WASHER-TOP LOADING
Maytag LAT9593AAL WASHER-TOP LOADING
Maytag LAT9593AAW WASHER-TOP LOADING
Maytag LAT9593ABL WASHER-TOP LOADING
Maytag LAT9593ABW WASHER-TOP LOADING
Maytag LAT9600AAL WASHER-TOP LOADING
Maytag LAT9600AAW WASHER-TOP LOADING
Maytag LAT9600ABL WASHER-TOP LOADING
Maytag LAT9600ABW WASHER-TOP LOADING
Maytag LAT9604AAE WASHER-TOP LOADING
Maytag LAT9604AAL WASHER-TOP LOADING
Maytag LAT9604AAM WASHER-TOP LOADING
Maytag LAT9604ABE WASHER-TOP LOADING
Maytag LAT9605AAE WASHER-TOP LOADING
Maytag LAT9605AAM WASHER-TOP LOADING
Maytag LAT9606AAE WASHER-TOP LOADING
Maytag LAT9606AAM WASHER-TOP LOADING
Maytag LAT9606ABE WASHER-TOP LOADING
Maytag LAT9606ABM WASHER-TOP LOADING
  #2 (permalink)
Old 02-02-2011, 03:51 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Once this pump starts to leak, it's a gonner.
Part number: AP4372888
  #3 (permalink)
Old 02-12-2011, 02:17 PM
Junior Member
Default
I installed a new pump; no more leaking. But I am curious as to what the screw on the side of the pump is for.
  #4 (permalink)
Old 02-12-2011, 08:03 PM
Senior Expert
APP Volunteer
Default
Can't say I've ever messed with it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Drain Pump Won't Stop CharlieSummers Dishwasher Repair 1 07-07-2010 05:51 AM
Maytag washer leaking, Seems to come from Pump mikou Washer Repair 2 11-11-2009 07:23 PM
New pump but washer will still not drain FredPam Washer Repair 5 08-29-2009 05:01 PM
Whirlpool washer leaking drain pump stuck to motor shaft, how to separate to replace? ennemm Washer Repair 1 05-03-2009 02:03 PM
Bosch washer- leaking at pump assembly PBroadfoot Washer Repair 2 01-19-2008 08:57 AM
