| » Whirlpool washer overflow |
Model Number: LSq9549LW2 Brand: Whirlpool Age: 5 - 10 years
I have searched thru the other "overflow" issues in the database and cannot find one exactly like mine. So here goes.
set the water level to anything (small-super) set for a regular wash cycle pull the knob and the tub fills to approx whatever level you set it to and the agitator starts up BUT the water does not stop filling. Will continue until it overflows and never stop. (Initially assumed pressure switch was fine since agitator starts) I checked the hose to the pressure switch and it is fine. I attach a separate hose to the pressure switch and blow into it (constant pressure). The agitator starts up but water keeps flowing...... so I replaced the pressure switch anyway and it still overflows I unpluged the washer while filling and the water stops. Plug it back in and water begins filling again and doesnt stop. I replaced the water inlet valve anyway and it still overflows. Started the washer and turn the water valves off at the wall after it fills up. Then open the valves when it goes into spin. The water doesnt come on in spin BUT when it gets to the rinse cycle it overflows again. HELP! Ads By Google Related Models |
Did you check the fill tube hose for any cracks?
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
I didn't catch that it overflows also in rinse. More likely , then, to be a bad pressure switch, or air is somehow getting into the system somewhere between the air dome and the pressure switch.
Wanted to clarify the pressure switch replacement. I hooked a seperate hose to the switch and blew into the hose, when the washer is filling, this causes the agitator to start but does not stop the water from filling up. if I stop blowing(eliminate the presessure) the agitator stops.
Here is your tech sheet
https://www.servicematters.com/docs/...%203955499.pdf Did this thing ever run correctly or did you buy it used and it has never worked? Your description does indicate that the water inlet valve is OK. Looking at the wiring diagram, it definitely shows that when the water level switch trips the water valve should disconnect. You have replaced the water level switch and getting a replacement that has the same fault as the original is extremely low. I mean the switch does detect the level because agitation starts so the switch trips the Normally Open contacts (closes them) but still keeps the Normally Closed contacts closed, it would have to do this to give you the symptoms you have. Never seen this in 25 years. Only explanation that makes sense is the unit is miswired or there is a short between two wires. The valve must be getting power from a line other than just the one coming from the level switch. Of course this assumes that the wiring diagram is correct.
__________________
| Display Modes | |
| Washer overflow | nightglow1 | Washer Repair | 2 | 01-13-2010 01:36 PM |
| Washer won't spin or drain = overflow | claudema | Washer Repair | 3 | 11-18-2009 05:14 PM |
| washer overflow | R Creation | Washer Repair | 2 | 08-13-2009 02:10 PM |
| Where can i find a Frigidaire Washer manual - overflow issue | kevbayer | Washer Repair | 3 | 03-05-2009 01:15 PM |
| New Whirlpool Overflow & Leak? | ddmouse | Washer Repair | 3 | 02-09-2008 08:28 PM |
