Discuss
Amana lwa40aw2 won't agitate
 in
Washer Repair
Hi, I have an Amana LWA40AW2 washer, it fills fine when the macine starts to agitatae the motor will kick
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Amana lwa40aw2 won't agitate
  #1 (permalink)
Old 02-01-2011, 11:21 AM
Junior Member
Swoopilot is on a distinguished road
Default Amana lwa40aw2 won't agitate
Brand: Amana   Age: More than 10 years
Hi, I have an Amana LWA40AW2 washer, it fills fine when the macine starts to agitatae the motor will kick in and start to turn the drum and shut off in a few seconds and start again and run a few seconds & shut off. If I run the spin cycle the motor starts slowly and will run the complete cycle. The transmission seems to be working ok, possibly a motor? Thanks for your help
Ads By Google
  #2 (permalink)
Old 02-01-2011, 12:26 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
This is a very difficult machine to work on. It's labor-intensive just to replace the belt. You have to pull the pump off to remove the belt. My recommendation is that you remove the belt and see if the motor will operate in the agitate direction, without a load on it. If it will, it's probably OK.
Here's a PDF that may help.
  #3 (permalink)
Old 02-01-2011, 12:34 PM
Junior Member
Default
Quote:
I repaired the pump & replaced the belt a couple of months ago. The motor will start to move the drum in the agitate direction then click off pause a min. or two restart and do the same.
  #4 (permalink)
Old 02-01-2011, 01:19 PM
Senior Expert
APP Volunteer
Default
From this description, I would suspect a bad motor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Washer wont agitate jassaf Washer Repair 0 06-01-2010 07:39 PM
Amana won't spin/agitate mikefried Dishwasher Repair 1 04-20-2009 01:20 PM
Amana Washer will not agitate CowboyRT Washer Repair 0 02-16-2009 11:18 AM
amana will not agitate, does spin rbeattie32 Washer Repair 0 05-28-2008 09:02 PM
Amana washer won't agitate dsperlne Washer Repair 0 08-27-2007 03:00 PM
