Discuss
Whirlpool duet won"t start
 in
Washer Repair
Originally Posted by Tdouble14 I'm having a problem with my ghw9100lw where the timer changes when selecting different cycles, buttons
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool duet won"t start
  #11 (permalink)
Old 02-22-2016, 06:41 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by Tdouble14 View Post
I'm having a problem with my ghw9100lw where the timer changes when selecting different cycles, buttons all work but won't start. I tried billions of times to due the diagnostics test but the time just flickers when pressing the rinse hold button for the fourth time. On top of that when I'm in this cycle setting ready for diagnostics if I press start I hear a click in the back and the number flashes. I'm truly at a lost because I can't find anything online dealing with the machine showing no error codes or not going into diagnostic mode.
Tdouble, Remove the top panel, and unplug the power cord from the outlet, locate the CCU, it's attached to the side or back wall of the cabinet. Listen closely, when you plug the cord back into the outlet, you should hear a click from the line relay on the control board. If the click occurs, use the attached tech sheet to access and check the user interface and control panel keys, and the harness between the UIC and The CCU. Review the troubleshooting information at the end of the manual, it'll help you to find a place to start the diagnosis process.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #12 (permalink)
Old 12-17-2016, 11:22 PM
Member
scottthefixitguy is on a distinguished road
Default
If your duet washer won't start its most likely due to a bad part behind the start button.
Here's how to fix it at home for 35 cents: https://youtu.be/N8rz8sclwAg
  #13 (permalink)
Old 12-17-2016, 11:23 PM
Member
Default Quick fix for broken start button
  #14 (permalink)
Old 12-19-2016, 09:21 AM
Senior Expert
Default
Scott, Thanks for the update and the You Tube Repair Video. We appreciate it.
__________________
Joe M. APP TEAM
  #15 (permalink)
Old 12-19-2016, 09:56 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Quote:
Are you in charge here?
Just in case you didn't notice, Scott is a SPAMBOT. "he" posted that same post in 7 other places on this forum and twice in this thread.
The youtube address he links to is youtu.be. Yeah, that just ain't right!
Notice the link below. youtube. Its a real one, his is not.
https://www.youtube.com/watch?v=Q3eYF53Pj8g
  #16 (permalink)
Old 12-19-2016, 10:24 AM
Senior Expert
Default
That Guy, No I'm not in charge, I've been here a while, bit I don't post or reply to the repair forum as often as I used to.
I don't know of Scotthefixitguy, and yes he has posted the you tube video several times, but it was a quick simple temporary repair and easy for most DIY'rs to view and repair the machine. I'm sure there are other methods and components to use for a more permanent repair, but thought it would be helpful, down the line. Thanks for the update and heads up.
__________________
Joe M. APP TEAM
  #17 (permalink)
Old 01-02-2017, 11:02 PM
Member
Default How to fix the Duet Washer broken start button with Duct Tape
Here is a video on how to repair the broken start button using duct tape.
It saves you about $300.00 on a new interface control board.
Hope this helps: https://youtu.be/N8rz8sclwAg
Good Luck,
Scott
  #18 (permalink)
Old 12-06-2017, 05:42 PM
Junior Member
Brt123 is on a distinguished road
Default
Happy mom how did you get your machine working? I'm ready to blow this one up!!! It's doing as you posted. Thx Brandon
  #19 (permalink)
Old 12-07-2017, 06:23 AM
Senior Expert
Default
Quote:
BRT123, Happy Mom didn't post a response or an update. But , Like her and most of the people on this thread, you most likely have a problem with the user interface tabs, so you'll need to remove power and access the user interface and check for broken buttons and tabs. All the information you need is posted through out the thread(including the service manual) Once you're there and determine the problem isn't the User Interface, drop us a line, and let us know what you did find, and we'll carry on from there. Thanks,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore/Whirlpool Duet "oil canning" gjferg Washer Repair 4 09-17-2012 06:37 PM
Whirlpool duet wont start when start button is pushed happymom Washer Repair 1 02-02-2011 07:28 AM
Whirlpool Duet "F" Code chadwmc Washer Repair 1 06-09-2010 08:02 AM
Whirlpool Duet - Will not start rdg1237 Washer Repair 10 09-22-2009 04:50 AM
Whirlpool Duet No Heat always "sensing" jimbonnet Dryer Repair 6 01-21-2009 07:13 PM
