Discuss
FAV6800A/FAV9800A Outer Tub bearing replacement
 in
Washer Repair
""I just can't seem to pull the spinner plate out! I've had it soaking in PB Blaster for a day....any
Appliance Repair Forum > Appliance Repair Help > Washer Repair » FAV6800A/FAV9800A Outer Tub bearing replacement
  #201 (permalink)
Old 09-19-2013, 11:57 PM
Senior Member
dh1200s is on a distinguished road
Default
""I just can't seem to pull the spinner plate out! I've had it soaking in PB Blaster for a day....any suggestions?""
John did you remove the spinner nut from the Spinner support? See page 48 and 49 of the SM step 24, 25, and 26 pics.
  #202 (permalink)
Old 09-20-2013, 02:25 AM
Junior Member
copiercop is on a distinguished road
Default
Hi Dick,
Hmmm....I was actually following page 45 of the SM which directed me to remove the six spinner bolts.
Step 10 says to just "lift spinner from washer"...no mention of the spinner nut....
So, it's apparent I will need to take out the tub to access the spinner nut...tonight's project!
  #203 (permalink)
Old 09-20-2013, 06:21 AM
Senior Member
Default
Follow the the first several pages of this thread of the two forum members that did the rebuilds on there machine along with the SM points on Outer Tub removal. I used the locking ring and tool that is shown in the manual to remove the Spinner Nut. I had the Outer Tub on the floor upside down. Just throw something under the upside down Outer Tub to cushion the fall of the Spinner Support as you remove that 1 3/4 spinner nut. It will come crashing down to the floor.
Keep in mind the inner tub has fluid sealed in it......it's not old wash water I mention that in the first several pages of this thread.
Did your machine use the Upper One-Way Bearing Ring that is mounted above the Clutch Pulley? If so you have the the 1st generation Outer Tub installed in your machine and that make the rebuild a bit less painless.
I'll try to help if you have questions......I'm a bit slow to respond at times with job and and home time issues. I'm always looking for other forum members to jump in with there support........Good Luck with the rebuild.......Dick
  #204 (permalink)
Old 09-20-2013, 07:45 AM
Junior Member
Default
Yes...my machine uses the upper one-way bearing.
Curious, why would the SM state I needed only to remove the 6 spinner screws on page 45 with no mention of the spinner nut?
Nonetheless, I'll "dive" into the tub tonight.
Thanks for the feedback...
Johnny
  #205 (permalink)
Old 09-20-2013, 11:25 AM
Senior Member
Default
Johnny
Is the SM the perfect document for a complete Outer Tub tear down.......nope. But as I mentioned it speaks to Spinner Support removal starting on page 48............... step 24 covers removing the 1.75 inch Spinner Nut.
  #206 (permalink)
Old 09-20-2013, 11:33 AM
Junior Member
Default
Thanks again...I will get on that this evening.
Do you suggest removing the tub entirely or is there enough room when the tub swivels?
  #207 (permalink)
Old 09-21-2013, 07:21 AM
Senior Member
Default
If you are just replacing the Tub Seal that may work out for you. But you mentioned removing/replacing the Outer Tub bearings so I would remove the Outer Tub for a bearing replacement.
Are you replacing the Clutch Pulley assembly? I'm sure you found it rusted up if the Clutch Pulley has not been replaced recently.
I would suggest on a new Clutch Pulley re-lube with WD-40. Those One-Way bearings become sticky in the Clutch Pulley and do not lock up properly you get tumbler movement as you enter into a Spin Cycle and unbalance errors become a real PITA. See this post for that issue and how to check both the Clutch Pulley One-Way bearing and the Upper One-Way bearing ring for proper One-Way bearing lock up.
Maytag Neptune load unbalance
Google for best price for the 6207-2RS bearings and support this forum for Tub Seal and Tranny O-ring purchase.
Make sure you remove the Old Tub Seal Sleeve from the spinner Support shaft as discussed multiple times in this thread.
Dick
  #208 (permalink)
Old 09-21-2013, 07:30 AM
Junior Member
Default
Hi Dick,
I am looking to replace all the bearings and the clutch pulley. I finally removed the tub last night. I have tried everything to remove the spinner nut with no luck. I've got the nut pinned with a socket but I can't seem to get the spinner to break free. I am turning the spinner CW as the nut is locked in place. I've soaked it in PB Blaster but am getting nowhere. Any thoughts?
Johnny
  #209 (permalink)
Old 09-21-2013, 07:40 AM
Junior Member
Default
One more question. Does the tub seal sleeve come with the tub seal?
Johnny
  #210 (permalink)
Old 09-21-2013, 08:04 AM
Senior Member
Default
Johnny
Easy question first yep.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
FAV6800A/FAV9800A Service Manual dh1200s Washer Repair 32 04-24-2011 08:24 PM
Rear outer tub bearing wore out? budrooms Washer Repair 1 09-04-2010 04:24 PM
Outer tub bearing sleeve stuck Spclist Washer Repair 3 12-29-2009 03:20 AM
outer glass door replacement PJLuvy Oven Repair (including Ranges and Cooktops) 0 02-18-2009 09:45 AM
Oven Outer Door Replacement cnowen Oven Repair (including Ranges and Cooktops) 1 09-08-2007 01:15 AM
