Discuss
Whirlpool washer has the shakes
 in
Washer Repair
My mother has the above washer and it shakes like crazy on the spin cycle. The shaking is so bad
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer has the shakes
  #1 (permalink)
Old 01-28-2011, 04:40 PM
Junior Member
wjbertrand is on a distinguished road
Default Whirlpool washer has the shakes
Model Number: LSQ8243HQ0   Brand: Whirlpool   Age: 1 - 5 years
My mother has the above washer and it shakes like crazy on the spin cycle. The shaking is so bad it bangs against the wall, the dryer and even walks out of place as far as the drain hose will allow. It's obviously out of balance but I can find no reason for it. I checked inside and all of the damper springs (or whatever they are called) are in place. There's nothing stuck under the agitator and I even tried to see if there's something between the basked and the outer bowl, but there's nothing there. Any idea what the fix is?
Ads By Google
Related Models
Whirlpool LSQ8243HQ0
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
Whirlpool LSQ8500JQ2
Whirlpool LSQ8500JT0
Whirlpool LSQ8500JT1
Whirlpool LSQ8500JT2
Whirlpool LSQ8500LQ0 Automatic Washer
Whirlpool LSQ8510LQ0 Automatic Washer
Whirlpool LSQ8511KQ0
Whirlpool LSQ8511KT0
Whirlpool LSQ8512KQ0
Whirlpool LSQ8512KT0
Whirlpool LSQ8520JQ0
Whirlpool LSQ8520JQ1
Whirlpool LSQ8543JQ0
Whirlpool LSQ8543JQ1
Whirlpool LSQ8543JT0
Whirlpool LSQ8543JT1
Whirlpool LSQ8543JZ0
Whirlpool LSQ8543JZ1
Whirlpool LSQ9010KQ0
Whirlpool LSQ9010KT0
Whirlpool LSQ9010LG0
Whirlpool LSQ9010LG1 Automatic Washer
Whirlpool LSQ9010LG2 Automatic Washer
Whirlpool LSQ9010LG3 Automatic Washer
Whirlpool LSQ9010LQ0
Whirlpool LSQ9010LQ1 Automatic Washer
Whirlpool LSQ9010LQ2 Automatic Washer
Whirlpool LSQ9010LW0
Whirlpool LSQ9010LW1 Automatic Washer
Whirlpool LSQ9010LW2 Automatic Washer
Whirlpool LSQ9010LW3 Automatic Washer
Whirlpool LSQ9010PG0 Automatic Washer
Whirlpool LSQ9010PG1 Automatic Washer
Whirlpool LSQ9010PG2 Automatic Washer
Whirlpool LSQ9010PG3 Automatic Washer
Whirlpool LSQ9010PG5 Automatic Washer
Whirlpool LSQ9010PG6 Automatic Washer
Whirlpool LSQ9010PW0 Automatic Washer
Whirlpool LSQ9010PW1 Automatic Washer
Whirlpool LSQ9010PW2 Automatic Washer
Whirlpool LSQ9010PW3 Automatic Washer
Whirlpool LSQ9010PW5 Automatic Washer
Whirlpool LSQ9010PW6 Automatic Washer
Whirlpool LSQ9030PQ0 Automatic Washer
Whirlpool LSQ9030PQ1 Automatic Washer
Whirlpool LSQ9030PQ2 Automatic Washer
Whirlpool LSQ9030PQ4 Automatic Washer
Whirlpool LSQ9030PQ5 Automatic Washer
Whirlpool LSQ9110KQ0
Whirlpool LSQ9110KQ1
Whirlpool LSQ9110LG0
Whirlpool LSQ9110LG1 Automatic Washer
Whirlpool LSQ9110LW0
Whirlpool LSQ9110LW1 Automatic Washer
Whirlpool LSQ9110PW0 Automatic Washer
Whirlpool LSQ9110PW1 Automatic Washer
Whirlpool LSQ9110PW2 Automatic Washer
Whirlpool LSQ9110PW3 Automatic Washer
Whirlpool LSQ9110PW4 Automatic Washer
Whirlpool LSQ9200KQ0
Whirlpool LSQ9200KT0
Whirlpool LSQ9200LQ0
Whirlpool LSQ9200LQ1 Automatic Washer
Whirlpool LSQ9200LQ2 Automatic Washer
Whirlpool LSQ9200LQ3 Automatic Washer
Whirlpool LSQ9200LT0
Whirlpool LSQ9200LT1 Automatic Washer
Whirlpool LSQ9200LT2 Automatic Washer
Whirlpool LSQ9200LT3 Automatic Washer
Whirlpool LSQ9200PQ0 Automatic Washer
Whirlpool LSQ9200PQ1 Automatic Washer
Whirlpool LSQ9200PQ3 Automatic Washer
Whirlpool LSQ9200PQ4 Automatic Washer
Whirlpool LSQ9200PT0 Automatic Washer
Whirlpool LSQ9200PT1 Automatic Washer
Whirlpool LSQ9200PT3 Automatic Washer
Whirlpool LSQ9200PT4 Automatic Washer
Whirlpool LSQ9210HQ0
Whirlpool LSQ9210HZ0
Whirlpool LSQ9211KQ0
Whirlpool LSQ9211KQ1
Whirlpool LSQ9211KT0
Whirlpool LSQ9211KT1
Whirlpool LSQ9244EQ0
Whirlpool LSQ9244EZ0
Whirlpool LSQ9264HQ0
Whirlpool LSQ9264HZ0
Whirlpool LSQ9500LQ0
Whirlpool LSQ9500LT0
Whirlpool LSQ9510JQ0
Whirlpool LSQ9510JQ1
Whirlpool LSQ9510LQ0
Whirlpool LSQ9510LT0
Whirlpool LSQ9520LQ0
Whirlpool LSQ9520LT0
Whirlpool LSQ9544KQ0
Whirlpool LSQ9544KT0
Whirlpool LSQ9549LG0
Whirlpool LSQ9549LG1 Automatic Washer
Whirlpool LSQ9549LG2 Automatic Washer
Whirlpool LSQ9549LG3 Automatic Washer
Whirlpool LSQ9549LQ0
Whirlpool LSQ9549LQ1 Automatic Washer
Whirlpool LSQ9549LQ2 Automatic Washer
Whirlpool LSQ9549LQ3 Automatic Washer
Whirlpool LSQ9549LW0
Whirlpool LSQ9549LW1 Automatic Washer
Whirlpool LSQ9549LW2 Automatic Washer
Whirlpool LSQ9549LW3 Automatic Washer
Whirlpool LSQ9549PG0 Automatic Washer
Whirlpool LSQ9549PG1 Automatic Washer
Whirlpool LSQ9549PG2 Automatic Washer
Whirlpool LSQ9549PG3 Automatic Washer
Whirlpool LSQ9549PG5 Automatic Washer
Whirlpool LSQ9549PG6 Automatic Washer
Whirlpool LSQ9549PW0 Automatic Washer
  #2 (permalink)
Old 01-29-2011, 03:52 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Remove the outer panel and inspect the skateboard under the tub, check both sides, might be out of place. Also, pry up the tub and check the brown plastic slides, might be missing or worn. Also, make sure all four feet are touching the floor.
__________________
  #3 (permalink)
Old 01-29-2011, 05:56 AM
Junior Member
Default
Thanks. What's the skate board?
  #4 (permalink)
Old 01-29-2011, 09:28 AM
Senior Expert
APP Volunteer
Default
The movable triangular metal frame under the tub is the skateboard, might be out of place on one side. The three, brown plastic slides clip on to the top of it.
__________________
  #5 (permalink)
Old 01-29-2011, 07:24 PM
Junior Member
Default
Quote:
OK, thanks. Took it apart and can't see anthing obvious. The slides look to be in place and in decent shape. The frame seems centered to the tub and it doesn't slide far enough aside that anything contacts. There's no banging noises when it shakes, just a whole lotta shaking going on. I'm wondering if the laminate floor (which I think is installed over some kind of felt) might be part of the problem?
  #6 (permalink)
Old 01-30-2011, 01:32 AM
Senior Expert
APP Volunteer
Default
A lot of these direct drive washers shake from brake shoes that are not evenly releasing, and the floor may not help. Other things to check are, a loose spin basket, half busted comb filter under it, or a leaky, plastic stabilizer on top of the basket.
You can screw a piece of thick plywood to the floor to help, or add a 6 inch spring to the back spring (AP4459650). Best to add the spring as a weak, or broken spring there will cause a flood!! Add some grease to the back spring frame hole to prevent it from wearing a slot in the hole.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer vibrates, shakes during spin cycle DanS Washer Repair 5 06-13-2011 01:10 PM
Washer Tub Shakes Violently paperlady Washer Repair 5 10-26-2010 08:33 AM
Roper washer shakes BAD! Amanda626 Washer Repair 1 08-21-2009 07:11 AM
Washer Noises and Shakes Trey723 General Talk 3 03-04-2009 11:28 AM
Washer Shakes A Lot LAXTON Washer Repair 2 10-30-2008 04:07 PM
