Ge Front Load Washer just stop and pause during a wash. I try to shut power off to get out of cycle and it door locks, and wont do anything then when it comes back goes to same cycle but only rotates 2 revolutions both ways and then nothing. It does count down but that is it? Do I need a reset and if so how to perform a reset? Thank you
I cannot get your model number to come up, and GE does not release tech info so I can only suggest that you look inside the top or lower service panel for tech notes that should enable you to put it into a diagnosis mode.
