Discuss
Water leak
 in
Washer Repair
About 2 months ago i replaced the transmission and the clutch in my maytag neptune FAV6800AWW and also put in
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water leak
  #1 (permalink)
Old 01-28-2011, 11:53 AM
Junior Member
jimoto is on a distinguished road
Angry Water leak
Model Number: FAV6800AWW   Brand: Maytag   Age: 5 - 10 years
About 2 months ago i replaced the transmission and the clutch in my maytag neptune FAV6800AWW and also put in a new seal.A weeks ago it broke the belt.I took it appart and found out that the bearings were dry (washed out with water).I loosened up the bearings (greased them up),put a new belt on and everything is working OK beside the fact that it is very noisy and leaking water through the clutch assembly.
What can i do?
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 01-28-2011, 10:46 PM
Senior Member
dh1200s is on a distinguished road
Default
Sorry to hear of your issues. What is the first two digits of your FAV6800A s/n (Series Number (10 thru 17)?
When you replaced the tub seal did you remove old inner sleeve that will normally need to be pried off the Spinner Support shaft? See Pic's.
I would not use grease on the One-Way Clutches Needle bearing in the Clutch Hub. I wash with WD-40 then dry/clean with a lint free cloth then re-lube with Slick-50 One Lube.
When you replaced the Tranny did you replace the Rubber O-Ring?
Why was the Tranny replaced?
How did you torque down the Spinner Nut? Did your tub have the notches in it (Series 10 & 11) to use the locking nut and spanner wrench? See Pic.
I did a Series 10 Outer Tub bearing replacement, Spinner support agitator shaft bearing replacement upper and lower caged bearing and the Tub Seal/Tranny O-ring replacement with no issues. It was my first tear down so I’m no expert. I did fill the tub with water and let it set for a week (Leak Check) before I reinstalled.........Dick
File Type: jpg 2 Work you way around the sleeve prying up.JPG (78.8 KB, 26 views)
  #3 (permalink)
Old 01-29-2011, 02:30 PM
Junior Member
Default Water leak
I did replace the inner sleeve from the shaft,the o-ring underneath the trans and the clutch assembly.I thought after i did this i would have a brake for a while.That didn"t happen.Anyway,the first 2 digits for S/N are 11.I did use a low torque setting on my impact wrench to tighten it up.
I'm sure it was torqued down pretty well.
I can not understand why it's leaking.I'm finishing my last load of laundry today (soaking up water with towels) and i'm going to tear it down again and see what i can come up with.I will keep in touch.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Leak tinkerer7 Refrigerator & Freezer Repair 0 07-27-2010 09:07 PM
Water leak glennyh Refrigerator & Freezer Repair 1 07-27-2010 03:29 PM
water leak in front of refrigerator when using water dispenser RichardCh Refrigerator & Freezer Repair 0 08-10-2009 10:29 AM
water leak in back from water line TRUSTART Refrigerator & Freezer Repair 1 04-05-2009 07:01 AM
Water Leak PyrFun Washer Repair 0 01-12-2009 12:30 PM
