| » Water does not enter washer |
Model Number: FWT445GES2 Brand: Frigidaire Age: More than 10 years
Water does not enter the wash on any cycle. I will turn the knob and choose a wash cycle and pull the knob. Usually there will be water beginning to enter. The only sound I get is a low hum. The problem happened just after a finished wash. I have replaced the water inlet valve. It did not solve the problem. Please help.
Rodney Ads By Google Related Models |
Well, you have gone after the obvious cause, so now you need to check other things. The pressure switch is another obvious problem, as is the door lock, the wiring and the timer.
Use a meter to check continuity, and here is a service manual which should help you with the process. http://frigidaireservicetips.com/pdf...ionWashers.pdf
__________________
If you have the service manual you know what we know. The door lock assembly is the likely source of the problem, I would replace it and see if that fixes things.
If you buy from this site and the part does not repair the problem you can return it, see the returns policy for conditions.
__________________
| Display Modes | |
| Water does not enter machine | mainuh | Dishwasher Repair | 4 | 02-11-2010 05:06 PM |
| Bosch Dishwasher - Water will not enter | gitai | Dishwasher Repair | 0 | 01-01-2010 08:38 PM |
| water does not enter dishwasher | dack | Dishwasher Repair | 1 | 09-23-2009 01:52 AM |
| can't get water to enter to wash | justasking | Dishwasher Repair | 0 | 08-02-2009 06:54 PM |
| water doesn't enter | rtrammell | Dishwasher Repair | 1 | 10-12-2008 04:20 AM |
