Discuss
maytag switch removal
 in
Washer Repair
How to remove the lid switch on a double stack washer dryer.The lid switch is in the back rt
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag switch removal
  #1 (permalink)
Old 10-13-2007, 05:31 PM
jerman jerman is offline
Junior Member
jerman is on a distinguished road
Red face maytag switch removal
Model Number: lsg7806aae   Brand: Maytag   Age: 5 - 10 years
How to remove the lid switch on a double stack washer dryer.The lid switch is in the back rt side of the washer tub up high.The front panel removes and one screw on the top mount between the dryer and the washer was difficult to remove but did so and still cannot see to remove the lid switch.Do I need to remove the dryer on top to get to the other screw ie to remove.Question.
Checking lid switch:as the electrical diagram shows the timer in the fill wash cycle the voltage at the motor (black wire)should be 120 volts.No voltage read at the motor.No advancement on the timer.The only cycle that works is by manually advancing the timer to the pump cycle and that is the only part of the wash cycle that works.The water will not fill in the tub,the timer will not advance,the agitation cycles will not work.Suspect the lid switch as the water valve solenoids and main timer have been replaced trying to dicypher the problem.Please lend your expertise.Thanks John Jerman
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-13-2007, 09:11 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Did you check the fuse?
If you remove the front of the washer there is a fuse hold on the left front end of the washer.
It have replace a couple of these lid switch. It's been sometime ago.
I do remember that you do not have to do anything with the dryer.
From what I recall I removed the front of the washer and then the top of the washer so I could flip the top over and replace the switch.
Take a look at that fuse first.
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lower Spray Arm Removal Chuckjacobs123 Dishwasher Repair 5 11-26-2007 12:15 PM
removal of shelf stud gjaffers Refrigerator & Freezer Repair 0 09-02-2007 10:56 PM
Cabinet removal jumbyway Washer Repair 1 08-23-2007 12:07 PM
Maytag Dryer front panel removal jkbatt Dryer Repair 0 08-23-2007 07:49 AM
Transmission Removal Street777 Washer Repair 0 08-01-2007 05:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
