Discuss
Bad noise & erratic motion when agitator runs
 in
Washer Repair
I ran it with the cabinet off and used the screwdriver/stethascope test to isolate the noise. It appears to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Bad noise & erratic motion when agitator runs
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-13-2007, 04:14 PM
k8mp k8mp is offline
Junior Member
k8mp is on a distinguished road
Default Bad noise & erratic motion when agitator runs
Model Number: KAWE560WWH2   Brand: Kitchen Aid   Age: More than 10 years
I ran it with the cabinet off and used the screwdriver/stethascope test to isolate the noise. It appears to be coming from the clutch.
What are the steps to remove it?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-14-2007, 03:49 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Either you have a bad tranny or a stripped agitator. I would remove agitator and check splines. If ok I would pull motor and pump and turn tranny coupler counterclockwise. If you feal tranny clunking you have a bad tranny.
__________________
  #3 (permalink)
Old 10-15-2007, 05:57 AM
Junior Member
Default The agitator looks OK
Is it safe the lay the washer on its side when removing the motor & tranny?
  #4 (permalink)
Old 10-15-2007, 09:51 AM
Senior Expert
APP Volunteer
Default
I never do this, I just tilt it back sufficiently to remove tranny, just less work.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Washer Agitator randym Washer Repair 1 09-20-2008 06:42 AM
Top agitator slipping robejahori Washer Repair 7 04-23-2008 09:14 AM
Agitator won't move Lou Caples Washer Repair 1 11-20-2007 09:32 PM
Washer Agitator won't turn nflordeliza Washer Repair 2 10-17-2007 05:04 PM
How to Replace top agitator? JasonS Washer Repair 2 08-18-2007 07:56 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
