| » how to replace washer gasket |
Model Number: MHWZ600TW Brand: Maytag Age: 1 - 5 years
How do I replace a leaking gasket in the front door of the washer?
Is it easy or hard? Will I need any special equipment? Dr. Jaffe Ads By Google Related Models |
Quote:
Dr. Jaffe, No, you won't really need special tools, It's not a really hard repair to perform, Here are excerpts from the service manual, and a part number for the bellows Part number: AP4379904 REMOVING THE CONSOLE AND THE TOUCHPAD/LED ASSEMBLY 1. Unplug washer or disconnect power. cover, then lift the cover off the unit.2. Turn off the water supply to the washer. 3. Remove the three T-20 hex-head Torx screws from the top cover of the washer. 4. Pull back on the cover and release the tabs in the console from the slots in the 5. To remove the console: a) Pull out and disconnect cable connector drawer from the unit.UI8 from the central control unit. b) Remove the cable wires from the two central control unit clips. c) Pull the detergent dispenser drawer out as far as it will go, then press down on the release tab, and remove the d) Remove the one screw at the recessed hole. e) Lift the top edge of the console and unhook it from the holder clips. f) Press the locking tab on the right rear the console.side of the console inward, and remove Removing the front panels 10. Remove the three hex-head screws from the lower front access panel, then lower the panel, and remove it. 11. Open the washer door. 12. Using a small screwdriver or a pair of long-nosed pliers, pull the tension spring on the retaining wire out from around the front of the bellows, and remove the wire. 13. Pull the bellows off the lip of the front panel, and push the bellows inside the front panel. 14. Remove the two T-20 Torx screws from the door switch assembly. 15. Close the washer door. 16. Remove the four hex-head screws from the top and bottom of the front panel and remove the panel from the unit. 17. Loosen the clamp from the main water feed tube and remove the tube from the detergent dispenser. REASSEMBLY NOTE: When you reconnect the water feed tube, align the arrow on the tube with the line on the detergent dispenser.18. Pull back and unhook the tab on the left side of the detergent dispenser from the cabinet side panel slot, then lift the dispenser out of the washer. To remove the bellows: c) Turn the bellows retaining clamp screw end of the clamp.counterclockwise until the clamp is loose enough to remove it from around the bellows NOTE: It may be necessary to completely remove the screw from one d) Remove the bellows retaining clamp from around the bellowse) Pull the bellows off the front of the tub. Remove Bellows REASSEMBLY NOTE: When you reinstall the bellows, be sure to position the “weep holes” at the bottom. It looks and sounds worse than it is.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| How To - replace gasket on washer | davidee | Washer Repair | 5 | 06-07-2010 05:22 AM |
| replace door gasket | jeannie52sugar | Refrigerator & Freezer Repair | 0 | 11-24-2009 05:21 AM |
| how to replace gasket kenmore he2 washer | gasket | Refrigerator & Freezer Repair | 0 | 07-22-2009 04:49 PM |
| Replace Ice dispenser gasket | jcoreno | Refrigerator & Freezer Repair | 2 | 10-26-2007 02:21 PM |
| gasket refrigerator replace | tmjm04 | Refrigerator & Freezer Repair | 0 | 08-21-2007 05:10 PM |
