Discuss
Cycle Stopped
 in
Washer Repair
During the cycle, the washer stopped with water in it. I tried to get it to drain but nothing would
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Cycle Stopped
  #1 (permalink)
Old 01-26-2011, 09:34 PM
Junior Member
ecarmack1 is on a distinguished road
Default Cycle Stopped
Model Number: LA4800XSW0   Brand: Whirlpool   Age: 5 - 10 years
During the cycle, the washer stopped with water in it. I tried to get it to drain but nothing would happen. When I pressed in the washer door button I could hear a buzzing. I took off the shell and found out the buzzing was coming from the motor. The motor doesn't run when this is happening. The buzzing does stop after a couple of seconds. I then took off the water pump to see if the motor was frozen but I could turn the motor shaft with my hand. Any suggestions??? Thanks for your help.
Ads By Google
Related Models
Whirlpool LA4800XSW0
Whirlpool LA4800XTF0
Whirlpool LA4800XTF1
Whirlpool LA4800XTG0
Whirlpool LA4800XTG1
Whirlpool LA4800XTM0
Whirlpool LA4800XTM1
Whirlpool LA4800XTN0
Whirlpool LA4800XTN1
Whirlpool LA4800XTW0
Whirlpool LA4800XTW1
Maytag LA482 Washer - Top Loading
Maytag LA482T Washer - Top Loading
Maytag LA484 Washer - Top Loading
Maytag LA484T Washer - Top Loading
Maytag LA490 Washer - Top Loading
Frigidaire LA490AXD1 Wwh(v4) / 27 " Washer
Frigidaire LA490AXW1 Wwh(v3) / 27 " Washer
Maytag LA490T Washer - Top Loading
Maytag LA4910 Washer - Top Loading
Maytag LA500 Washer - Top Loading
Maytag LA5000 Washer - Top Loading
Whirlpool LA5000XMW0
Whirlpool LA5000XPW0
Whirlpool LA5000XPW1
Whirlpool LA5000XPW2
Whirlpool LA5000XPW3
Whirlpool LA5000XPW4
Whirlpool LA5000XPW5
Whirlpool LA5000XSW0
Whirlpool LA5000XSW1
Frigidaire LA500AXD5 Wwh(v2) / 27 " Washer
Frigidaire LA500AXD6 Wwh(v2) / 27 " Washer
Frigidaire LA500AXW5 Wwh(v1) / 27 " Washer
Frigidaire LA500AXW6 Wwh(v1) / 27 " Washer
Frigidaire LA500EXD3 Wwh(v6) / Top Loading Washer
Frigidaire LA500EXF3 Wwh(v7) / Top Loading Washer
Frigidaire LA500EXH3 Wwh(v8) / Top Loading Washer
Frigidaire LA500EXV3 Wwh(v9) / Top Loading Washer
Frigidaire LA500EXW3 Wwh(v10) / Top Loading Washer
Frigidaire LA500JXD3 Wwh(v11) / Washer
Frigidaire LA500JXD4 Wwh(v11) / Top Load Washer
Frigidaire LA500JXD5 Wwh(v7) / Top Load Washer
Frigidaire LA500JXF3 Wwh(v12) / Washer
Frigidaire LA500JXF4 Wwh(v12) / Top Load Washer
Frigidaire LA500JXH3 Wwh(v13) / Washer
Frigidaire LA500JXH4 Wwh(v13) / Top Load Washer
Frigidaire LA500JXH5 Wwh(v8) / Top Load Washer
Frigidaire LA500JXV3 Wwh(v14) / Washer
Frigidaire LA500JXV4 Wwh(v14) / Top Load Washer
Frigidaire LA500JXW3 Wwh(v15) / Washer
Frigidaire LA500JXW4 Wwh(v15) / Top Load Washer
Frigidaire LA500JXW5 Wwh(v9) / Top Load Washer
Frigidaire LA500MXD1 Wwh(v3) / 27 " Washer
Frigidaire LA500MXD2 Wwh(v3) / 27 " Washer
Frigidaire LA500MXH1 Wwh(v2) / 27 " Washer
Frigidaire LA500MXH2 Wwh(v2) / 27 " Washer
Frigidaire LA500MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA500MXW2 Wwh(v1) / 27 " Washer
Maytag LA502 Washer - Top Loading
Maytag LA503 Washer - Top Loading
Maytag LA506 Washer - Top Loading
Maytag LA506T Washer - Top Loading
Maytag LA510 Washer - Top Loading
Whirlpool LA5100XTF0
Whirlpool LA5100XTF1
Whirlpool LA5100XTG0
Whirlpool LA5100XTG1
Whirlpool LA5100XTM0
Whirlpool LA5100XTM1
Whirlpool LA5100XTN0
Whirlpool LA5100XTN1
Whirlpool LA5100XTW0
Whirlpool LA5100XTW1
Frigidaire LA510MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA510MXW1 Wwh(v1) / 27 " Washer
Maytag LA510S Washer - Top Loading
Maytag LA511 Washer - Top Loading
Maytag LA511S Washer - Top Loading
Maytag LA512 Washer - Top Loading
Maytag LA512S Washer - Top Loading
Maytag LA512ST Washer - Top Loading
Maytag LA512T Washer - Top Loading
Frigidaire LA515LXD1 Wwh(v2) / Top Load Washer
Frigidaire LA515LXW1 Wwh(v1) / Top Load Washer
Whirlpool LA5200XTF0
Whirlpool LA5200XTF1
Whirlpool LA5200XTG0
Whirlpool LA5200XTG1
Whirlpool LA5200XTM0
Whirlpool LA5200XTM1
Whirlpool LA5200XTN0
Whirlpool LA5200XTN1
Whirlpool LA5200XTW0
Whirlpool LA5200XTW1
Whirlpool LA5243XYN0
Whirlpool LA5243XYN1
Whirlpool LA5243XYW0
Whirlpool LA5243XYW1
Whirlpool LA5280XTF0
Whirlpool LA5280XTF1
Whirlpool LA5280XTG0
Whirlpool LA5280XTG1
Whirlpool LA5280XTM0
Whirlpool LA5280XTM1
Whirlpool LA5280XTN0
Whirlpool LA5280XTN1
Whirlpool LA5280XTW0
Whirlpool LA5280XTW1
Whirlpool LA5300XKW0
Whirlpool LA5300XKW1
Whirlpool LA5300XMW0
Whirlpool LA5300XMW1
Whirlpool LA5300XPW0
Whirlpool LA5300XPW1
Whirlpool LA5300XPW2
Whirlpool LA5300XPW3
Whirlpool LA5300XPW4
Whirlpool LA5300XPW5
Whirlpool LA5300XSW0
  #2 (permalink)
Old 01-27-2011, 06:38 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
You may have somethng jammed under the agitator, but more likely something jammed in the transmission or the coupling came apart and is jamming the machine.
See if the coupling is ok, and see if you can use it to turn the transmission. Pull out the transmission and check it for leaks.
__________________
  #3 (permalink)
Old 01-31-2011, 12:14 PM
Junior Member
Default
The coupling looks fine. I tried turning the tranny and it does turn and the agitator turns as well. Should I get the motor tested? Or do you recommend something else.
  #4 (permalink)
Old 01-31-2011, 01:13 PM
Senior Expert
APP Volunteer
Default
Well, the motors on these models almost never fail, and your symptons now indicate a problem with the capacitor, but it almost never fails also.
A few days ago someone posted with the same symptoms and it turned out the capacitor had become disconnected from the motor, which also almost never happens. So I would
1. Check the motor connections and the connections with the capacitor.
2. If they check out, try changing out the capacitor.
3. If it checks out, then maybe it is the motor.
As Sherlock Holmes said, when you have eliminated the impossible, whatever is left, however improbably must the be the trust, although to be fair he never repaired a washer.
Good luck, let us know how it turns out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer stopped mid cycle molney Dryer Repair 1 08-07-2009 02:12 PM
Stopped mid-cycle Winslow Washer Repair 3 06-07-2009 10:33 AM
Stopped in rinse cycle pktzygt Washer Repair 1 01-04-2009 09:59 AM
Whirlpool stopped mid cycle poolbad Dishwasher Repair 0 04-01-2008 06:32 PM
Stopped on Spin Cycle rjr13 Washer Repair 0 01-21-2008 09:00 AM
