Discuss
washer drum
 in
Washer Repair
can a chip in the finish of a washer drum be repaired
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer drum
  #1 (permalink)
Old 12-06-2008, 05:58 AM
Junior Member
mrshiff is on a distinguished road
Default washer drum
Brand: -brand-   Age: Less than 1 year
  #2 (permalink)
Old 12-06-2008, 06:56 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I have never done this but it should work.
Clean the area with a soap solution and then with vinegar.
Get it as clean as you can
If rusty sand it with medium emery cloth till clean.
If the area is a little rough the coating will adhere better.
Then I would get a bottle of the stuff that is used to repair dishwasher racks.
It has good adhesion and soap has no effect on it.
I would paint on several light coats instead of one heavy coat.
Could also use an epoxy buy get one that is optimized for metal.
5 minute epoxy will just peel off after a few washes.
Perhaps someone else will have personal experience with this a specific epoxy to use.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer drum will not spin craigjr Washer Repair 17 08-13-2015 05:51 PM
Washer drum seems to have fallen down grosemont@hvc.rr.com Washer Repair 1 07-19-2009 04:26 PM
oil leak in drum of washer? janbish Washer Repair 1 04-23-2009 08:45 PM
Duet Washer Drum Nut Ryanc Washer Repair 4 08-29-2008 05:44 AM
Washer Drum out of balance dcophil Washer Repair 1 01-06-2008 10:09 PM
