The cold water wont shut off when filling the basket it even continues flowing in when knob is pushed to off the hot water works fine it started intermittenly now is everytime i have to turn off cold water faucet n shut washer down move knob to a further spot on dial then turn it on, the washer that is and then turn water on at faucet and it doesnt add anymore water what can this be something in the knob of the water level or what??? the first time it happened i changed the water level while it was filling to extra large load and it overflowed onto the floor etc but that was months ago now it doesnt shutoff at all on any water level i have to do it as described above and i cant afford to hire a repair person so need your help so i can fix this myself
The cold water supply is controlled by a selenoid valve. It is possible that the selenoid valve is bad and needs replacing. There could also be trash under the seat of the valve but if there is a screene before it that may not be the problem. To check it out, run the washer while it is filling. Take a small screwdriver and place it over the coil - you should feel a magnetic field that has an effect on the screwdriver. When the cycle is finished, check the coil again - if you still have a magnetic field pulling on the screwdriver, the control board is probably causing the problem If there is no power then the selenoid valve is bad and needs replacing. SteveKJR Originally Posted by: debhug The cold water wont shut off when filling the basket it even continues flowing in when knob is pushed to off the hot water works fine it started intermittenly now is everytime i have to turn off cold water faucet n shut washer down move knob to a further spot on dial then turn it on, the washer that is and then turn water on at faucet and it doesnt add anymore water what can this be something in the knob of the water level or what??? the first time it happened i changed the water level while it was filling to extra large load and it overflowed onto the floor etc but that was months ago now it doesnt shutoff at all on any water level i have to do it as described above and i cant afford to hire a repair person so need your help so i can fix this myself
