| » samsung washer problems |
Model Number: wf306law/xaa Brand: Samsung Age: 1 - 5 years
my washing machine started leaking on the fill cycle I removed the top cover and found a plastic box that has three hoses going to it that was cracked and spraying cold water. I took it off and sealed it up that stopped the leak but it appears that the drum (front loader) is out of balance even on very small loads it bounces around more than usual. after two weeks of use it started leaking again it is the same box it appears that the out of balance drum is hitting the box and beaking it.
My questions are if you think the damper shocks are bad and what is the difference between part #ap4044557 and #ap4206554 and then also the "box" I can't find the part anywhere on the website on the wiring diagram it is listed as a"silver kit" stamped on it is guide-water DC61-01558A could you please share any info possible asap thanks Ads By Google Related Models |
| Display Modes | |
| Samsung door display problems | Joem88 | Refrigerator & Freezer Repair | 3 | 08-23-2010 02:07 PM |
| Samsung washer | Wendy D | Washer Repair | 0 | 08-22-2010 05:23 PM |
| Samsung Fridge Problems | KatHorner | Refrigerator & Freezer Repair | 1 | 11-17-2009 04:50 AM |
| samsung washer | gerry gesner | Washer Repair | 0 | 08-17-2009 12:48 PM |
| samsung washer | joesindone | Washer Repair | 1 | 02-16-2009 06:06 AM |
