Discuss
Can I replace ONLY the rear bearing assembly?
 in
Washer Repair
Here's what happened: The machine could not stand the wear put on it by the 8-10 people living in our
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Can I replace ONLY the rear bearing assembly?
  #1 (permalink)
Old 01-24-2011, 03:10 PM
Junior Member
jesseservin is on a distinguished road
Default Can I replace ONLY the rear bearing assembly?
Model Number: wfw8300sw05   Brand: Whirlpool   Age: 1 - 5 years
Here's what happened: The machine could not stand the wear put on it by the 8-10 people living in our house and gave way to terrible knocking during the spin cycle. It went ignored until it finally quit spinning all together. During the spin cycle, the drum quit spinning, but it sounded like the belt was trying to turn it regardless.
I had the machine diagnosed by a repair person as needing a new rear drum bearing kit, and belt. He said it was most likely caused by over loading the machine, which is very likely true.
After researching a bit, I could find no way of replacing the bearing alone, but would need to purchase the whole drum assembly, which I doubt is necessary seeing the machine is barely over a year old. I would much rather keep the current drum and replace the bearing separately. Any comments?
Also...seeing that the machine ran for some time while it was damaged, would there be need to worry about changing the shock absorber as well? Or should the new bearing/tub assembly and belt do the trick?
Thanks for any advice...
Jesse
Related Models
Whirlpool WFW8300SW05 AUTOMATIC WASHER
Whirlpool WFW8300SW1 AUTOMATIC WASHER
Whirlpool WFW8400TB00 AUTOMATIC WASHER
Whirlpool WFW8400TB01 AUTOMATIC WASHER
Whirlpool WFW8400TB02 AUTOMATIC WASHER
Whirlpool WFW8400TE00 AUTOMATIC WASHER
Whirlpool WFW8400TE01 AUTOMATIC WASHER
Whirlpool WFW8400TW00 AUTOMATIC WASHER
Whirlpool WFW8400TW01 AUTOMATIC WASHER
Whirlpool WFW8400TW02 AUTOMATIC WASHER
Whirlpool WFW8400TW03 AUTOMATIC WASHER
Whirlpool WFW8410SW0 AUTOMATIC WASHER
Whirlpool WFW8410SW01 AUTOMATIC WASHER
Whirlpool WFW8410SW02 AUTOMATIC WASHER
Whirlpool WFW8410SW03 AUTOMATIC WASHER
Whirlpool WFW8500SR0 AUTOMATIC WASHER
Whirlpool WFW8500SR01 AUTOMATIC WASHER
Whirlpool WFW8500SR02 AUTOMATIC WASHER
Whirlpool WFW8500SR03 AUTOMATIC WASHER
Whirlpool WFW8500SR04 AUTOMATIC WASHER
Whirlpool WFW9050XW00 AUTOMATIC WASHER
Whirlpool WFW9050XW01 AUTOMATIC WASHER
Whirlpool WFW9050XW02 AUTOMATIC WASHER
Whirlpool WFW9050XW03 AUTOMATIC WASHER
Whirlpool WFW9150WW00 AUTOMATIC WASHER
Whirlpool WFW9150WW01 AUTOMATIC WASHER
Whirlpool WFW9150WW02 AUTOMATIC WASHER
Whirlpool WFW9151YW00 WASHER
Whirlpool WFW9200SQ00 AUTOMATIC WASHER
Whirlpool WFW9200SQ01 AUTOMATIC WASHER
Whirlpool WFW9200SQ02 AUTOMATIC WASHER
Whirlpool WFW9200SQ03 AUTOMATIC WASHER
Whirlpool WFW9200SQ04 AUTOMATIC WASHER
Whirlpool WFW9200SQ10 AUTOMATIC WASHER
Whirlpool WFW9200SQA10 AUTOMATIC WASHER
Whirlpool WFW9200SQA11 AUTOMATIC WASHER
Whirlpool WFW9200SQA12 AUTOMATIC WASHER
Whirlpool WFW9250WL00 AUTOMATIC WASHER
Whirlpool WFW9250WL01 AUTOMATIC WASHER
Whirlpool WFW9250WL02 AUTOMATIC WASHER
Whirlpool WFW9250WR00 AUTOMATIC WASHER
Whirlpool WFW9250WR01 AUTOMATIC WASHER
Whirlpool WFW9250WR02 AUTOMATIC WASHER
Whirlpool WFW9250WW00 AUTOMATIC WASHER
Whirlpool WFW9250WW01 AUTOMATIC WASHER
Whirlpool WFW9250WW02 WASHER
Whirlpool WFW9300VU02 AUTOMATIC WASHER
Whirlpool WFW9300VU03 AUTOMATIC WASHER
Whirlpool WFW9300VU04 AUTOMATIC WASHER
Whirlpool WFW9351YL00 AUTOMATIC WASHER
Whirlpool WFW9351YW00 AUTOMATIC WASHER
Whirlpool WFW9400SB00 AUTOMATIC WASHER
Whirlpool WFW9400SB01 AUTOMATIC WASHER
Whirlpool WFW9400SB02 AUTOMATIC WASHER
Whirlpool WFW9400SBA10 AUTOMATIC WASHER
Whirlpool WFW9400ST00 AUTOMATIC WASHER
Whirlpool WFW9400ST01 AUTOMATIC WASHER
Whirlpool WFW9400ST02 AUTOMATIC WASHER
Whirlpool WFW9400STA10 AUTOMATIC WASHER
Whirlpool WFW9400SU00 AUTOMATIC WASHER
Whirlpool WFW9400SU01 AUTOMATIC WASHER
Whirlpool WFW9400SU02 AUTOMATIC WASHER
Whirlpool WFW9400SW00 AUTOMATIC WASHER
Whirlpool WFW9400SW01 AUTOMATIC WASHER
Whirlpool WFW9400SW02 AUTOMATIC WASHER
Whirlpool WFW9400SW03 AUTOMATIC WASHER
Whirlpool WFW9400SW04 AUTOMATIC WASHER
Whirlpool WFW9400SWA10 AUTOMATIC WASHER
Whirlpool WFW9400SZ00 AUTOMATIC WASHER
Whirlpool WFW9400SZ01 AUTOMATIC WASHER
Whirlpool WFW9400SZ02 AUTOMATIC WASHER
Whirlpool WFW9400SZ03 AUTOMATIC WASHER
Whirlpool WFW9400SZ04 AUTOMATIC WASHER
Whirlpool WFW9400SZA10 AUTOMATIC WASHER
Whirlpool WFW9400VE01 AUTOMATIC WASHER
Whirlpool WFW9400VE02 AUTOMATIC WASHER
Whirlpool WFW9400VE03 AUTOMATIC WASHER
Whirlpool WFW9410XW00 WASHER
Whirlpool WFW9450WL00 AUTOMATIC WASHER
Whirlpool WFW9450WR00 AUTOMATIC WASHER
Whirlpool WFW9450WW00 AUTOMATIC WASHER
Whirlpool WFW9451XW00 AUTOMATIC WASHER
Whirlpool WFW9470WL00 AUTOMATIC WASHER
Whirlpool WFW9470WL01 AUTOMATIC WASHER
Whirlpool WFW9470WR00 AUTOMATIC WASHER
Whirlpool WFW9470WR01 AUTOMATIC WASHER
Whirlpool WFW9470WW00 AUTOMATIC WASHER
Whirlpool WFW9470WW01 AUTOMATIC WASHER
Whirlpool WFW94HEXL0 WASHER
Whirlpool WFW94HEXL1 AUTOMATIC WASHER
Whirlpool WFW94HEXL2 AUTOMATIC WASHER
Whirlpool WFW94HEXR0 WASHER
Whirlpool WFW94HEXR1 AUTOMATIC WASHER
Whirlpool WFW94HEXR2 AUTOMATIC WASHER
Whirlpool WFW94HEXW0 WASHER
Whirlpool WFW94HEXW1 AUTOMATIC WASHER
Whirlpool WFW94HEXW2 AUTOMATIC WASHER
Whirlpool WFW9500TC00 AUTOMATIC WASHER
Whirlpool WFW9500TC01 AUTOMATIC WASHER
Whirlpool WFW9500TC02 AUTOMATIC WASHER
Whirlpool WFW9500TC03 AUTOMATIC WASHER
Whirlpool WFW9500TW00 AUTOMATIC WASHER
Whirlpool WFW9500TW01 AUTOMATIC WASHER
Whirlpool WFW9500TW02 AUTOMATIC WASHER
Whirlpool WFW9500TW03 AUTOMATIC WASHER
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
Whirlpool WFW9550WW10 AUTOMATIC WASHER
Whirlpool WFW95HEXL0 WASHER
Whirlpool WFW95HEXL1 AUTOMATIC WASHER
Whirlpool WFW95HEXL2 AUTOMATIC WASHER
Whirlpool WFW95HEXR0 WASHER
Whirlpool WFW95HEXR1 AUTOMATIC WASHER
Whirlpool WFW95HEXR2 AUTOMATIC WASHER
Whirlpool WFW95HEXW0 WASHER
  #2 (permalink)
Old 01-25-2011, 03:10 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Jesse
Jesse,
I am not aware of the manufacturer supplying a bearing or bearing repair kit for your unit,
You'll need to order and replace the rear tub assembly.
I wouldn't be too worried about a shock absorber.
I'd be more conscerned about a damaged or scarred spin tub shaft, that would require a spin tub as well, it doesn't occurr often, and minor damage can be repaired with emory cloth and a "shoe shine".
And you won't know until you tear down the unit.
It's relatively easy to do the repair, but it does have it's frustrating moments,
Let us know what you decide, so we can assist you, more.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-26-2011, 09:47 AM
Junior Member
Default
Thanks for the advice and heads up, I appreciate it. I'm gonna tear the machine down today, so I will post the outcome, maybe even some of the stages I encounter. I hope no further damage is revealed!!
  #4 (permalink)
Old 01-26-2011, 09:50 AM
Junior Member
Default
One more question: how does "shoe shine" repair damage to the spin shaft? And what's the difference between minor and major damage in this case? Will it be obvious?
  #5 (permalink)
Old 01-26-2011, 12:49 PM
Senior Expert
Default
Jesse,
Minor damage to the spinner shaft, would be light scratches, discoloration, very slight variation of the shaft, especially in the bearing areas.
You can usually get it re surfaced using emory cloth paper in the areas,and using a " shoe shine" buffing motion.
Major damage to the spinner shaft, would be very deep scratches, a blue discoloration, or gouges or metal splotches on the shaft in the bearing areas.
Like I said, you probably won't need a spinner tub, it's got to be pretty bad, I would guess there's a 90% chance you won't.
__________________
Joe M. APP TEAM
  #6 (permalink)
Old 01-27-2011, 02:10 PM
Junior Member
SteveKJR is on a distinguished road
Default Bearing Replacement
McMaster Carr carries bearings. You need to get the info off the bearing that is bad and see if you can match one up in their catalogue. They carry all kinds of bearings.
My dishwasher motor stopped working because the bearing where the seal is located was leaking and it eventually destroyed the bearing.
Disassembled the motor, took the bearing off and it just so happened that I had a replacement bearing that I purchased about 10 years ago from McMaster Carr. Checked the number on the bad bearing, and the bearing I had was an exact fit and replacement.
Cost about 1.0 hour to replace it after I cleaned and polished the shaft. Use a stro[ emory cloth along with penetrating oil - this will remove the rust and allow you to polish the shaft.
Hope this info helps.
SteveKJR
Jesse
  #7 (permalink)
Old 01-27-2011, 02:18 PM
Senior Expert
Default
SteveKJR
Steve,
Thanks for the bearing info, and your polishing info as well(I never used penetrating oil, but see how it would help, will keep that in mind).
Thanks Again,
__________________
Joe M. APP TEAM
  #8 (permalink)
Old 03-21-2011, 08:29 PM
Junior Member
Default
Thanks for the help Steve, and sorry about the late update.
I began dismantling the machine with the intention of replacing the entire rear drum assembly (as I hadn't seen this latest posting at the time), but stopped short once I seen that the bearing seemed to be in good condition. The pulley wheel and drive belt seemed to be the only parts that were damaged, so I replaced those parts, put it all back together and the machine has been running. Only now I think the drain pump has died, but that seems to be an unrelated problem. Thanks again for your help!!
  #9 (permalink)
Old 03-22-2011, 07:29 AM
Senior Expert
Default
Jesse,
Thanks for the update.
Glad, it wasn't as bad as it sounded at the start of this post.
As for the drain problem, you may want to remove the drain pump filter, and check it for debris and clogs, before you replace it.
Part number: AP3868483
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Rear Bearing Replace Or Purchase New Washer kdbennett36 Washer Repair 0 06-22-2010 10:37 AM
rear bearing gacotton Dryer Repair 5 03-12-2010 04:18 PM
rear bearing linus410 Dryer Repair 1 09-18-2009 10:01 PM
Rear Tub Bearing Justncase Washer Repair 5 08-08-2007 09:54 PM
Removing rear bearing above brake assembly Scott Washer Repair 2 08-04-2007 09:55 PM
