Discuss
Washer drains without spinning. Has loud humming sound
 in
Washer Repair
Machine washes fine. When ready to go into spin cycle the washer starts to drain but doesn't spin. You hear
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer drains without spinning. Has loud humming sound
  #1 (permalink)
Old 01-23-2011, 07:17 PM
Junior Member
ewc777 is on a distinguished road
Default Washer drains without spinning. Has loud humming sound
Model Number: LSQ9610JQ0   Brand: Whirlpool   Age: More than 10 years
Machine washes fine. When ready to go into spin cycle the washer starts to drain but doesn't spin. You hear a loud humming sound coming from the bottom of the unit. I have it apart now and looking at the drive block and spanner nut. I read in other responses that i should check to see if there is any wear on the block or shaft but i cant seem to remove either the block or the nut. Which one gets removed first to start. And it wasnt quite clear on how to actually remove the block to begin with. I can spin the inner tub by hand. It is a little hard to turn if that gives you any more insight. The humming sounds like its coming from beneath the tub. Motor spins fine. Can't really pinpoint the parts that the sound is coming from. This machine is just over 10 years old and is used a great deal, probably 5-9 loads a week.
Related Models
Whirlpool LSQ9610JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610LG0 AUTOMATIC WASHER
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
Whirlpool LSR5100KQ0 RESIDENTIAL WASHER
Whirlpool LSR5100LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ1 AUTOMATIC WASHER
Whirlpool LSR5102LQ1 AUTOMATIC WASHER
Whirlpool LSR5121HQ0 AUTOMATIC WASHER
Whirlpool LSR5121JQ0 AUTOMATIC WASHER,
Whirlpool LSR5132AG0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AN0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AW0 DIRECT-DRIVE WASHER
Whirlpool LSR5132HQ0 AUTOMATIC WASHER
Whirlpool LSR5132HQ1 AUTOMATIC WASHER
Whirlpool LSR5132JQ0 COMPACT WASHER
Whirlpool LSR5132JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR5132JQ2 WASHER - DIRECT DRIVE
Whirlpool LSR5132PQ0 AUTOMATIC WASHER
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
Whirlpool LSR5132PQ4 AUTOMATIC WASHER
Whirlpool LSR5232DW0 AUTOMATIC WASHER
Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5232LQ1 AUTOMATIC WASHER
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0 Washers*
Whirlpool LSR5233EQ0 AUTOMATIC WASHER
Whirlpool LSR5233EQ1 DIRECT-DRIVE WASHER
Whirlpool LSR5233EQ2 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132BN0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW1 AUTOMATIC WASHER
Whirlpool LSR6132DQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132DZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132EQ0 AUTOMATIC WASHER
Whirlpool LSR6132EQ1 AUTOMATIC WASHER
Whirlpool LSR6132EZ0 AUTOMATIC WASHER
Whirlpool LSR6132EZ1 AUTOMATIC WASHER
Whirlpool LSR6132HQ0 AUTOMATIC WASHER
Whirlpool LSR6132HQ1 AUTOMATIC WASHER
Whirlpool LSR6132HZ0 AUTOMATIC WASHER
Whirlpool LSR6232JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR6232JQ1 WASHER - DIRECT DRIVE
Whirlpool LSR6232JQ2 AUTOMATIC WASHER
Whirlpool LSR6233BG0 AUTOMATIC WASHER
Whirlpool LSR6233BN0 AUTOMATIC WASHER
Whirlpool LSR6233BN1 WASHER
Whirlpool LSR6233BW0 AUTOMATIC WASHER
Whirlpool LSR6233BW1 WASHER
Whirlpool LSR6233DN0 AUTOMATIC WASHER
Whirlpool LSR6233DW0 AUTOMATIC WASHER
Whirlpool LSR6244AW0 Washers*
Whirlpool LSR6332KQ0 WASHER
Whirlpool LSR6332KQ1 AUTOMATIC WASHER
Whirlpool LSR6334LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR6334LQ1 AUTOMATIC WASHER
Whirlpool LSR6335LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR7010PQ0 AUTOMATIC WASHER
Whirlpool LSR7010PQ1 AUTOMATIC WASHER
Whirlpool LSR7010PQ2 AUTOMATIC WASHER
  #2 (permalink)
Old 01-25-2011, 04:35 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
The drive block could be the problem, but more likely the issue is with the clutch and brakes.
See the Sticky by Richappy at the top of this page for info on how to check it out. I would start by replacing the clutch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Is Humming & Not Spinning mrs.roberson Washer Repair 0 06-14-2010 02:51 PM
Loud humming like sound, but working Briteblue Dryer Repair 2 03-18-2010 06:16 PM
Kenmore 17039 making loud humming sound RobWestergaard Dishwasher Repair 0 11-28-2009 10:27 AM
loud humming sound dryerasap2 Dryer Repair 2 11-30-2008 06:15 PM
Whirlpool Washer humming but not spinning hillaholic Washer Repair 1 10-31-2008 10:34 AM
