Discuss
Maytag Dependble - No Spin/Drain, Motr Hums - Belt Cn Be Rotatd by Hand 2 Start Motor
 in
Washer Repair
Thanks on the diagram. Not sure if you had a chance to read my most recent explanation to Rich of
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Dependble - No Spin/Drain, Motr Hums - Belt Cn Be Rotatd by Hand 2 Start Motor
  #11 (permalink)
Old 12-05-2008, 07:04 AM
Junior Member
bluestreak is on a distinguished road
Default
Thanks on the diagram. Not sure if you had a chance to read my most recent explanation to Rich of what happens but yes, whenever it is in any cycle that requires agitation or spinning, if I pull the selector knob out, the motor hums and machine sits idle. I then can start the belt by hand and it will agitate but in the Spin cycle I never do see it do the actual "fast spin" - just agitation and from what I had read on other forums this was because it won't spin if there is still water in it. But now after draining as much water as I can get out (can still see a little in the pump body), when I give it help to start up in the Spin Cycle, it just agitates during the whole spin cycle and then clicks off, and this is also position of Cycle Selector (although obviously I have no idea whether it is in true off or in some kind of final spin mode but not doing anything because of this problem.
Clear as mud... thanks again.
  #12 (permalink)
Old 12-05-2008, 11:00 AM
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
Here is how most Maytag motors are hot wired the Dependable care anyway
__________________
  #13 (permalink)
Old 12-06-2008, 02:53 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
You have to inspect the contacts by gently lifting each spring.
You can also spray the timer contacts with a non-residue cleaning spray while turning the timer. If then, the timer acts differently, you have a bad timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Used Maytag Washer-Motor Hums but wont start ronandtracey@charter.net Washer Repair 1 12-07-2009 07:12 PM
Motor hums,but won't start Richpeterson Dryer Repair 1 11-07-2009 06:31 AM
Motor Hums But Will Not Start dstraple Washer Repair 5 02-18-2009 05:01 AM
Gas dryer motor hums but won't start nonqual Dryer Repair 5 12-27-2007 05:40 AM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
