Hi, I have a maytag a612 that looks brand new. Purchased used 1 year ago.
In the spin cycle it seemed to always go out of balance so I tighted up the 3 anchor points to the tub which seemed to fix this issue. They were almost to the end of the threads on the eye bolt. I also by-passed the lid switch electrically.:eek:
Now the machine seems to be 'stuck' in gental agitation mode. When pushing the agitation buttons on control panel the motor makes the 'gear change' sound with little of no affect on agitation.
Spin cycle seems a bit slow but gets the job done.
I re-hooked up the lid switch and re-adjusted the achor nuts to see if this 'fixed' the agitation issue which it did not.
The belts seem to be very loose as far as V belts are concerned. They can be removed by hand.
Do you think the problem is loose belts that was just 'around the corner'?
Thanks in advance.
THIS FORUM IS DEAD!!!!!!! |
If you need to get by before you buy new belts, there is an adjustment of the pump. If you pull the washer away from the wall, and then lean it back. Then lay down on the ground, and take the belt off that goes from the pump to the motor. Now there are three 5/16s screws that hold the pump in place. If it has not been adjusted yet, and it might have, because that is an older washer. A true Maytag!!!! You can loosen those screws, and move it to the right, all the way, and then tighten the screws up, and then put the belt on. Let me know how it works. If after you replace belts, or make the adjustment, and you feel that the drum is still not turning fast enough, you might need to replace the spin bearing kit, and I could easily walk you through the repair. I have done a ton of them. Tom ApplianceEducator.com
