| » washer does not spin |
Model Number: PAVT244AWW Brand: Maytag Age: 5 - 10 years
WASHER DOES NOT SPIN OR AGGETATE
motor turns freely without belt. motor will turn and burn pully and belt transmission does turn but not very easy water pump ok not locked up if you take belt off turn motor on it works fine do you think maybe trans is bad Ads By Google Related Models |
If you can not move the drive pulley in both directions by hands then the transmission most likely is bad.
- The transmission Part number: AP4373431 Here are the breakdown diagrams and Replacement parts for MAYTAG PAVT244AWW WASHER-TOP LOADING | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
the drive shaft pulley
if I pull the belt off i can turn the transmission pully it does turn but it feels slugish so if i put it on a cycle it will fill the tank then when it goes to aggetate it locks up and pully on motor spins and starts to melt belt and pulley if I advance the cycle to rinse it will drain so motor is turning and belt is turning or water pump wont drain tank I just cant get it to aggetate |
Can you turn the drive pulley clockwise? If you can not then the transmission is locked up and has to be replaced.
__________________
| Display Modes | |
| Whirlpool washer won't spin on rinse cycle or high spin | bry21317 | Washer Repair | 10 | 05-24-2011 12:25 PM |
| washer does not spin, fills up and drain the water nornal but do not spin | leaderman | Washer Repair | 0 | 10-04-2010 02:28 PM |
| washer makes grinding noise and won't spin on spin cycle | marine1969 | Washer Repair | 1 | 08-30-2010 07:19 PM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
