Discuss
Roper washer starts to fill and stops
 in
Washer Repair
Washer starts to fill and stops after 5 sec onds or so. Press the button in and out and stars
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper washer starts to fill and stops
  #1 (permalink)
Old 01-17-2011, 08:33 AM
Junior Member
phish_phinder is on a distinguished road
Default Roper washer starts to fill and stops
Model Number: RTW4440VQ1   Brand: Roper   Age: 1 - 5 years
Washer starts to fill and stops after 5 sec onds or so. Press the button in and out and stars back for 5 seconds, once filled it works fine. What is the problem?
Related Models
Roper RTW4440VQ1 AUTOMATIC WASHER
Roper RTW4440VQ2 AUTOMATIC WASHER
Roper RTW4440XQ0 AUTOMATIC WASHER
General Electric RU38*C1 Electric range
General Electric RU38*C2 Electric range
General Electric RU38*C3 Electric range
General Electric RU380C3 ELECTRIC COOKTOP
General Electric RU38B*C1 Electric range
General Electric RU38B*C2 Electric range
General Electric RU38B*C3 Electric range
General Electric RU38B0C3 ELECTRIC COOKTOP
General Electric RU9150S RECOVERY PUMP
Roper RUD0800EB DISHWASHER
Roper RUD0800HB0 DISHWASHER
Roper RUD1000DB0 UNDERCOUNTER DISHWASHER
Roper RUD1000DB1 UNDERCOUNTER DISHWASHER
Roper RUD1000DB2 UNDERCONTER DISHWASHER
Roper RUD1000DB3 DISHWASHERS
Roper RUD1000DB4 UNDERCOUNTER DISHWASHER
Roper RUD1000HB0 DISHWASHER
Roper RUD1000HB1 DISHWASHER
Roper RUD1000KB0 DISHWASHER
Roper RUD1000KB1 DISHWASHER
Roper RUD1000KB3 UNDERCOUNTER DISHWASHER
Roper RUD3000DB0 UNDERCOUNTER DISHWASHER
Roper RUD3000DB1 UNDERCOUNTER DISHWASHER
Roper RUD3000DB2 UNDERCOUNTER DISHWASHER
Roper RUD3000DB3 UNDERCOUNTER DISHWASHER
Roper RUD3000DQ0 UNDERCOUNTER DISHWASHER
Roper RUD3000DQ1 UNDERCOUNTER DISHWASHER
Roper RUD3000DQ3 UNDERCOUNTER DISHWASHER
Roper RUD3000GB0 UNDERCOUNTER DISHWASHER
Roper RUD3000GB1 UNDERCOUNTER DISHWASHER
Roper RUD3000GQ0 UNDERCOUNTER DISHWASHER
Roper RUD3000GQ1 UNDERCOUNTER DISHWASHER
Roper RUD3000HB0 DISHWASHER
Roper RUD3000HB1 DISHWASHER
Roper RUD3000HQ0 DISHWASHER
Roper RUD3000HQ1 DISHWASHER
Roper RUD3000KB0 DISHWASHER
Roper RUD3000KB1 DISHWASHER
Roper RUD3000KQ0 DISHWASHER
Roper RUD3000KQ1 DISHWASHER
Roper RUD3006DB0 UNDERCOUNTER DISHWASHER
Roper RUD3006DB1 UNDERCOUNTER DISHWASHER
Roper RUD3006DB2 UNDERCOUNTER DISHWASHER
Roper RUD3006DB3 DISHWASHERS
Roper RUD4000MB0 UNDERCOUNTER DISHWASHER
Roper RUD4000MB2 UNDERCOUNTER DISHWASHER
Roper RUD4000MQ0 UNDERCOUNTER DISHWASHER
Roper RUD4000MQ2 UNDERCOUNTER DISHWASHER
Roper RUD4000MU0 UNDERCOUNTER DISHWASHER
Roper RUD4000MU1 UNDERCOUNTER DISHWASHER
Roper RUD4000MU2 UNDERCOUNTER DISHWASHER
Roper RUD4000SB0 UNDERCOUNTER DISHWASHER
Roper RUD4000SB1 UNDERCOUNTER DISHWASHER
Roper RUD4000SQ0 UNDERCOUNTER DISHWASHER
Roper RUD4000SQ1 UNDERCOUNTER DISHWASHER
Roper RUD4000SU0 UNDERCOUNTER DISHWASHER
Roper RUD4300DQ2 UNDER-COUNTER DISHWASHER
Roper RUD4300DQ3 DISHWASHERS
Roper RUD4500DB0 UNDERCOUNTER DISHWASHER
Roper RUD4500DB1 UNDERCOUNTER DISHWASHER
Roper RUD4500DB2 UNDERCOUNTER DISHWASHER
Roper RUD4500DB3 DISHWASHERS
Roper RUD4500DB4 UNDERCOUNTER DISHWASHER
Roper RUD4500MB0 UNDERCOUNTER DISHWASHER
Roper RUD4500MB2 UNDERCOUNTER DISHWASHER
Roper RUD4500MQ0 UNDERCOUNTER DISHWASHER
Roper RUD4500MQ2 UNDERCOUNTER DISHWASHER
Roper RUD5000HB0 DISHWASHER
Roper RUD5000HB1 DISHWASHER
Roper RUD5000HQ0 DISHWASHER
Roper RUD5000HQ1 DISHWASHER
Roper RUD5000KB0 DISHWASHER
Roper RUD5000KB1 UNDERCOUNTER DISHWASHER
Roper RUD5000KQ0 DISHWASHER
Roper RUD5000KQ1 UNDERCOUNTER DISHWASHER
Roper RUD5750DB0 UNDERCOUNTER DISHWASHER
Roper RUD5750DB1 UNDERCOUNTER DISHWASHER
Roper RUD5750DB2 DISHWASHER
Roper RUD5750DB3 DISHWASHERS
Roper RUD5750DB4 UNDERCOUNTER DISHWASHER
Roper RUD5750DQ0 UNDERCOUNTER DISHWASHER
Roper RUD5750DQ1 UNDERCOUNTER DISHWASHER
Roper RUD5750DQ2 DISHWASHER
Roper RUD5750DQ3 DISHWASHERS
Roper RUD5750DQ4 UNDERCOUNTER DISHWASHER
Roper RUD5750HB0 DISHWASHER
Roper RUD5750HQ0 DISHWASHER
Roper RUD5750KB0 DISHWASHER
Roper RUD5750KB1 DISHWASHER
Roper RUD5750KQ0 DISHWASHER
Roper RUD5750KQ1 DISHWASHER
Roper RUD6000PB2 UNDERCOUNTER DISHWASHER
Roper RUD6000PQ2 UNDERCOUNTER DISHWASHER
Whirlpool RUD6050RD0 UNDERCOUNTER DISHWASHER
Roper RUD6050RD2 UNDERCOUNTER DISHWASHER
Roper RUD8000RQ0 UNDERCOUNTER DISHWASHER
Roper RUD8000RQ1 UNDERCOUNTER DISHWASHER
Roper RUD8000SQ0 UNDERCOUNTER DISHWASHER
Roper RUD8050RD0 UNDERCOUNTER DISHWASHER
Roper RUD8050SD0 UNDERCOUNTER DISHWASHER
Roper RUD8050SD1 UNDERCOUNTER DISHWASHER
Roper RUD8050SD2 UNDERCOUNTER DISHWASHER
Amana RV-10 COMMERCIAL MICROWAVES
Amana RV-10A COMMERCIAL MICROWAVES
Amana RV-8 COMMERCIAL MICROWAVES
Amana RV10 COMMERCIAL MICROWAVES
Roper RV1088RBW00 VERTICAL FREEZER
Amana RV10A COMMERCIAL MICROWAVES
Amana RV10AT COMMERCIAL MICROWAVES
Roper RV1299RBW00 FREEZER
Roper RV1299RBW01 FREEZERS
Roper RV1299REW00 REFRIGERATORS
  #2 (permalink)
Old 01-17-2011, 08:50 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Does it act the same in all the possible wash/rinse combinations you can select?
  #3 (permalink)
Old 01-17-2011, 09:02 AM
Junior Member
Default
Yes, normal , gentle , and perm. press all do the same thing.
  #4 (permalink)
Old 01-17-2011, 09:21 AM
Senior Expert
APP Volunteer
Default
I would suspect either ayour temperature selector switch, or a bad timer.
  #5 (permalink)
Old 01-17-2011, 09:26 AM
Junior Member
Default
I only use cold cold.... I do not have hot water supply. If I switch setting you say it might work?
  #6 (permalink)
Old 01-17-2011, 09:33 AM
Senior Expert
APP Volunteer
Default
If you switch the setting, and it does the same thing, I would suspect the timer.
AFTERTHOUGHT:
Check to see if the air tube from the water lever switch is clogged, kinked, or otherwise restricted. This switch really controlls the voltage to the water inlet valve; When the switch is satisfied (by pressure related to your fill level selected), the voltage to the valve is interrupted, and the timer then takes over the operation. If there is a restriction in the tube or the air dome attached to the tub (this can be a lint clog), the switch can be tricked into "thinking" there's water in the tub.
Tell us what you find.
  #7 (permalink)
Old 01-17-2011, 11:22 AM
Junior Member
Default
Someone switched it to hot cold not knowing we didnt have hot water , problem solved, cant believe i overlooked where the setting was assuming i always keep it on cold cold, thanks for your help and glad I found this forum.
Reply
« TUB repair | washer »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer fills, buzzes, stops, later starts bob4843 Washer Repair 5 07-19-2010 09:48 AM
Whirlpool Washer Starts Stops And Hums beverlyjean Washer Repair 1 06-02-2009 06:09 PM
Whirlpool Washer Starts Stops And Hums beverlyjean Washer Repair 1 06-02-2009 02:35 PM
Washer starts and stops during wash cycle ballardg Washer Repair 1 02-27-2009 04:28 PM
washer stops and hums, after cooldown starts again gmboetr Washer Repair 1 05-15-2008 06:42 PM
