Discuss
Lint filter locking up under tub?
 in
Washer Repair
The other day my washing machine stopped going into the spin cycle. The agitator still worked, filled and drained properly,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Lint filter locking up under tub?
  #1 (permalink)
Old 12-01-2008, 09:23 AM
vand0521 vand0521 is offline
Junior Member
vand0521 is on a distinguished road
Default Lint filter locking up under tub?
Model Number: 90 Series - 110.xxxx   Brand: Kenmore   Age: More than 10 years
The other day my washing machine stopped going into the spin cycle. The agitator still worked, filled and drained properly, just didn't spin so clothes came out dripping wet. I read around and thought that the problem was a worn out clutch. Bought a new one, replaced it, still no spin. I then proceeded to rip apart the agitator and tub to see if I could see anything. What I found, and I think is the problem, is that the lint filter - I think that's what it's called, the plastic piece that the metal tub sits on or spins on is stuck to the actual outer tub. I assume that should be freely spinning with the metal inner tub? I found this diagram online, #12.
http://www.applianceaid.com/pictures...tor-basket.jpg
I broke it while messing around with it so I'll have to replace it no matter what...... but before I bought it I wanted to confirm that this part should be spinning with the inner tub was the problem.
Thanks!
Related Models
Amana 90/46EVP500 Commercial Microwaves
Amana 90/46EVP600 Commercial Microwaves
Amana 90/56EVP500 Commercial Microwaves
Amana 90/56EVP600 Commercial Microwaves
Hardwick 90131 Range - F/s Std Ele
Hardwick 90138 Range - F/s Std Ele
Amana 904.000 Mwave - Family Size (60 Hz)
Amana 904.001 Mwave - Family Size (60 Hz)
Amana 904.002 Mwave - Family Size (60 Hz)
Amana 904.101 Mwave - Family Size (60 Hz)
Amana 904.A
Magic Chef 90F-3KLX
Magic Chef 90F-3KW
Magic Chef 90F-3KX
Magic Chef 90FA-3KLX Walloven - Cont Clean Gas
Magic Chef 90FA-3KW Walloven - Std Gas
Magic Chef 90FA-3KX Walloven - Std Gas
Magic Chef 90FN-3KLX Walloven - Cont Clean Gas
Magic Chef 90FN-3KW Walloven - Std Gas
Magic Chef 90FN-3KX Walloven - Std Gas
Magic Chef 90FW-3KLX
Magic Chef 90FW-3KW
Magic Chef 90FW-3KX
Magic Chef 90H-4KLX
Magic Chef 90H-4KVW
Magic Chef 90H-4KW
Magic Chef 90H-4KX
Magic Chef 90HA-4KLX Walloven - Cont Clean Gas
Magic Chef 90HA-4KVW
Magic Chef 90HA-4KW Walloven - Std Gas
Magic Chef 90HA-4KX Walloven - Std Gas
Magic Chef 90HN-4KLX Walloven - Cont Clean Gas
Magic Chef 90HN-4KVW Walloven - Std Gas
Magic Chef 90HN-4KW Walloven - Std Gas
Magic Chef 90HN-4KX Walloven - Std Gas
Hoover 91 Frigidaire/range
Kenmore 911.04698680  KENMORE ELECTRIC RANGE
Kenmore 911.04698690  KENMORE ELECTRIC RANGE
Kenmore 911.3202090  GAS COUNTER UNIT
Kenmore 911.3202091  30" GAS COUNTER UNIT
Kenmore 911.32080100  30" GAS COOKTOP
Kenmore 911.32085890  30" GAS COUNTER UNIT
Kenmore 911.32088890  30" GAS COUNTER UNIT
Kenmore 911.32089890  30" GAS COUNTER UNIT
Kenmore 911.3212590  30" GAS COUNTER UNIT
Kenmore 911.3212990  30" GAS COUNTER UNIT
Kenmore 911.32212100  COOKTOP
Kenmore 911.32212101  30" GAS COOKTOP
Kenmore 911.32214100  COOKTOP
Kenmore 911.32214101  30" GAS COOKTOP
Kenmore 911.32219100  COOKTOP
Kenmore 911.32219101  30" GAS COOKTOP
Kenmore 911.32222100  36" GAS COOKTOP
Kenmore 911.32222101  36" GAS COOKTOP
Kenmore 911.32224100  36" GAS COOKTOP
Kenmore 911.32224101  36" GAS COOKTOP
Kenmore 911.32229100  36" GAS COOKTOP
Kenmore 911.32229101  36" GAS COOKTOP
Kenmore 911.32255590  30" GAS COUNTER UNIT
Kenmore 911.32255591  30" GAS COUNTER UNIT
Kenmore 911.32255592  30" GAS COUNTER UNIT
Kenmore 911.32259590  30" GAS COUNTER UNIT
Kenmore 911.32259591  30" GAS COUNTER UNIT
Kenmore 911.32285890  30" GAS COUNTER UNIT
Kenmore 911.32289890  30" GAS COUNTER UNIT
Kenmore 911.32355590  30" GAS COUNTER UNIT
Kenmore 911.32355591  30" GAS COUNTER UNIT
Kenmore 911.32356590  30" GAS COUNTER UNIT
Kenmore 911.32356591  30" GAS COUNTER UNIT
Kenmore 911.32359590  30" GAS COUNTER UNIT
Kenmore 911.32359591  30" GAS COUNTER UNIT
Kenmore 911.32384101  30" GAS COOKTOP
Kenmore 911.32385100  30" GAS COOKTOP
Kenmore 911.32385890  30" GAS COUNTER UNIT
Kenmore 911.32386890  30" GAS COUNTER UNIT
Kenmore 911.32389100  30" GAS COOKTOP
Kenmore 911.32389890  30" GAS COUNTER UNIT
Kenmore 911.3522190  GAS RANGE
Kenmore 911.3524190  KENMORE - 30" DROP-IN RANGE
Kenmore 911.3528611  KENMORE 30 INCH DROP-IN GAS RANGE
Kenmore 911.3528810  DROP IN GAS RANGE
Kenmore 911.3528812  DROP IN GAS RANGE
Kenmore 911.3542090  DROP-IN GAS RANGE
Kenmore 911.3544090  KENMORE 30" DROP-IN RANGE
Kenmore 911.3548691  KENMORE 30 INCH DROP-IN GAS RANGE
Kenmore 911.3548810  KENMORE GAS RANGE
Kenmore 911.3548813  DROP-IN GAS RANGE
Kenmore 911.3611190  GAS RANGE
Kenmore 911.3618810  KENMORE 30 IN GAS RANGE
Kenmore 911.3618811  GAS RANGE
Kenmore 911.3618890  KENMORE 30 IN GAS RANGE
Kenmore 911.3628610  KENMORE GAS RANGE
Kenmore 911.3628611  KENMORE GAS RANGE
Kenmore 911.3628690  KENMORE GAS RANGE
Kenmore 911.3628710  KENMORE GAS RANGE
Kenmore 911.3631990  GAS RANGE
Kenmore 911.3632090  SLIDE-IN RANGE
Kenmore 911.3638611  KENMORE GAS RANGE
Kenmore 911.3638690  KENMORE GAS RANGE
Kenmore 911.3638710  KENMORE GAS RANGE
Kenmore 911.3638810  KENMORE GAS RANGE
Kenmore 911.3638811  30" GAS RANGE
Kenmore 911.3638812  GAS RANGE
Kenmore 911.3651190  Slide-In Range, Gas
Kenmore 911.3652090  GAS RANGE
Kenmore 911.3652091  GAS RANGE
Kenmore 911.3652190  GAS RANGE
Kenmore 911.3652191  GAS RANGE
Kenmore 911.3654090  30" SELF-CLEANING OVEN
Kenmore 911.3654190  KENMORE 30" GAS SELF-CLEAN RANGE
Kenmore 911.3654191  30" SELF-CLEANING OVEN
Kenmore 911.3658610  KENMORE GAS RANGE
Kenmore 911.3658611  KENMORE GAS RANGE
Kenmore 911.3658690  KENMORE GAS RANGE
Kenmore 911.3658691  KENMORE GAS RANGE
Kenmore 911.3658790  KENMORE GAS RANGE
Kenmore 911.3658812  GAS RANGE
Kenmore 911.36655591  30" GAS SLIDE-IN RANGE
Kenmore 911.36655792  30" GAS SLIDE-IN RANGE
Kenmore 911.36655793  30" GAS SLIDE-IN RANGE
  #2 (permalink)
Old 12-01-2008, 09:43 AM
v2k04 v2k04 is offline
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
Those lint filters are discontinued and replaced with some cheap plugs that dont work save your money and just remove the filter and run without as they never worked the way they were intended to anyway
__________________
  #3 (permalink)
Old 12-01-2008, 09:47 AM
Junior Member
Default
great, thanks!
  #4 (permalink)
Old 12-01-2008, 10:00 AM
magician59 magician59 is offline
Senior Expert
APP Volunteer
magician59 is on a distinguished road
Default
Could you hear the motor running when in the spin cycle?
__________________
Nemo malus felix
  #5 (permalink)
Old 12-01-2008, 10:04 AM
Junior Member
Default
Yes. I tried running it in spin cycle without the lint filter and it works.... not sure if dirt and sand got underneath the lint filter causing it to jam up or what.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher Repair - Locking Parts daviswi Dishwasher Repair 3 06-29-2008 12:03 PM
Whirlpool Cabrio Locking Mechanism matthoover Washer Repair 0 06-27-2008 11:24 AM
GE Oven sporadic door locking issue myerswg Oven Repair (including Ranges and Cooktops) 1 04-28-2008 09:52 PM
Kenmore Dishwasher control panel locking up John Lee Dishwasher Repair 0 01-26-2008 05:13 PM
Lint Filter problem Dan Pearl Dryer Repair 1 11-08-2007 04:55 PM
