Andrewca
#1 Posted : Monday, December 1, 2008 6:43:15 AM(UTC)
Andrewca
The washer overflowed while in the rinse cycle. I removed some of the clothes thinking it was filled to much, but it did the same thing the second time around. Is there a float switch or something that is not working?
magician59
#2 Posted : Monday, December 1, 2008 8:16:33 AM(UTC)
magician59
Start the machine in any cycle. When you hear water entering, unplug the machine. If it continues to fill, you have a bad inlet valve. If it stops filling, the problem is more probably a dirty or clogged pressure hose, That's the hose that goes from the bottom right side of the outer tub to the water level switch. The switches rarely fail, but the hoses sometimes disconnect, get kinked or clogged, or split, allowing air to get into the hose.
Whirlpool MFX2571XEM0 Icemaker water overflow into ice holding bin (Refrigerator & Freezer Repair)
by Guest 8/30/2021 10:36:11 AM(UTC)
Water overflows ice maker and freezes on bottom. (Refrigerator & Freezer Repair)
by Kimlu 6/4/2016 8:43:37 AM(UTC)
water overflowing (Washer Repair)
by Josedejesus 5/2/2013 5:14:02 PM(UTC)
Maytag Neptune Water overflowing (Washer Repair)
by rboess 9/10/2012 5:58:48 AM(UTC)
Ice maker water overflow (Refrigerator & Freezer Repair)
by prniners 7/22/2012 7:47:30 PM(UTC)
Water Overflow (Washer Repair)
by Tenn47 12/6/2011 2:42:33 PM(UTC)
Water Overflowing (Washer Repair)
by FreeGumbo 10/1/2011 7:25:34 AM(UTC)
by bravohotel 8/3/2011 12:49:17 PM(UTC)
water overflowing (Refrigerator & Freezer Repair)
by arickt 7/23/2011 6:50:06 AM(UTC)
Icemaker water overflows (Refrigerator & Freezer Repair)
by Capro22340 3/31/2011 2:25:01 PM(UTC)
water overflow in rinse cycle (Washer Repair)
by david vogel 1/6/2011 6:35:16 AM(UTC)
Icemaker - water overflows during filling cycle (Refrigerator & Freezer Repair)
by BobW484 7/15/2010 11:45:22 AM(UTC)
Water Overflows (Washer Repair)
by COUNTRTAZ 5/31/2010 10:06:33 AM(UTC)
Water Overflows And Doesn't Stop On Fill Up (Washer Repair)
by GTA17 4/18/2010 1:14:58 PM(UTC)
by ChickenShack 4/6/2010 10:31:03 AM(UTC)
