Discuss
Kenmore Direct Drive Washer Spin cycle problem
 in
Washer Repair
Spin cycle operation is intermittent. I have replaced the timer, the clutch and now the transmission. The problem that I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Direct Drive Washer Spin cycle problem
  #1 (permalink)
Old 01-11-2011, 03:01 PM
Junior Member
rocky03 is on a distinguished road
Default Kenmore Direct Drive Washer Spin cycle problem
Model Number: 110.28932790   Brand: Kenmore   Age: More than 10 years
I have replaced the timer, the clutch and now the transmission. The problem that I observe is as follows: Washer spin is supposed to work as follows: 1) the motor runs one way and the machine agitates, 2) the motor pauses, 3) the motor runs the other way running the pump with the basket/transmission in neutral, 4) the motor pauses again, 5) the motor runs the same way a second time with both pump operation and basket spinnning. On mine, I can observe the agitate, then the pause and then things go wrong. Most of the time the basket begins to spin immediately on the first time the motor runs in the spin direction when the operation should be pump only. On the second time the motor runs in the spin direction the basket may or may not spin. Before I replaced the transmission the basket frequently did not spin the second time that the motor ran in the spin direction leaving the clothes wet from the spray rinse; I have tried it relatively few times since replacing the transmission, so am not sure whether it reliably spins or not but am pretty sure that it misses spinning sometimes. Both before and after changing the transmission, I have observed that most times the basket spins on the first cycle while draining which it should not; however, I have sometimes observed it just pumping/emptying without spinning both with old and new transmission. I have watched the timer operation with the lid switch defeated. In each case there is a very noticeable pause between between running of the motor of at least a few seconds so the timer at least visually appears to be working correctly. However; as a further check, again with the lid switch defeated, I tried setting the machine to wash letting it fill and agitate, then shutting off the machine with the timer switch and advancing the timer to the spin position and restarting the machine briefly, then shutting it off again with the timer switch and restarting it briefly. In every instance of repeated attempts of this approach the operation is as desired. Agitate, pump only, spin. It appears that somehow the motor pausing (and reversing as appropriate) under control of the timer does not cause the transmission to shift properly, but my pausing it and reversing it manually with the timer switch does result in proper operation. This is despite the fact that the motor appears to pause appropriately when under timer control. What else can cause the transmission to shift improperly? Is it possible, for example< that the motor starts "jerkily" or with a "stutter" that causes it to inadvertently shift the transmission improperly? When I start it manually, it the motor does opeate the transmission normally though.
Ads By Google
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 01-13-2011, 05:46 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Given the parts you replaced, your problem is somewhat of a mystery. You may have a wiring issue, which is going to be very difficult to detect since it is intermittent, or you may have a motor switch issue.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Direct Drive Washing Machine Knocks During Spin Cycle bwtaylor Washer Repair 6 07-27-2012 04:51 PM
Spin problem with Whirlpool direct drive washer msvolkert Washer Repair 4 07-31-2010 05:54 AM
Spin problem Direct Drive partymonster Washer Repair 12 08-23-2009 02:51 PM
Kenmore Direct Drive Won't Spin!! cjcoles Washer Repair 4 11-09-2008 12:38 PM
