Discuss
MAYTAG Leaks been w/o washer 3 WEEKS!
 in
Washer Repair
I do apologize if this is a repeat. I clicked the Submit New Thread button and then I was asked
Appliance Repair Forum > Appliance Repair Help > Washer Repair » MAYTAG Leaks been w/o washer 3 WEEKS!
  #1 (permalink)
Old 01-11-2011, 12:44 PM
Junior Member
cnjones is on a distinguished road
Exclamation MAYTAG Leaks been w/o washer 3 WEEKS!
Model Number: A712   Brand: Maytag   Age: More than 10 years
I do apologize if this is a repeat. I clicked the Submit New Thread button and then I was asked to register when I had already registered and was given permission to post, so I'm starting again hoping to actually get an important question answered.
We have purchased the Tub Bearing and Mounting Stem Repair Kits. We are quite sure these are the parts required to repair the leak in our older-than-the-hills Maytag washer. My question is regarding a metal spring that sits on the center shaft and an O-ring that coincides with part #14839 found on the Transmission Diagram & Parts List found on your website. In cleaning the crud from around the center shaft I used a wire brush. Did this damage the O-ring? There is no O-ring or spring in the kits I purchased. Are they necessary to replace? Are there any other parts I might need that I am not aware of? Do I leave the spring in place, or do I remove it? I am a fairly good handyman, but your professional guidance in this situation would be most appreciated as we have been without a washer for 3 weeks and we are starting to feel the pinch. Thank You.
Ads By Google
Related Models
Maytag A712 Washer - Top Loading
Maytag A712T Washer - Top Loading
Maytag A7300 Washer - Top Loading
Maytag A7400 Washer - Top Loading
Maytag A7500 Washer - Top Loading
Maytag A7500S Washer - Top Loading
Maytag A7500W Washer - Top Loading
Maytag A7800 Washer - Top Loading
Admiral A79E-5CXW Walloven - S/c Ele
Admiral A79F-5EXW-R Walloven - S/c Ele
Admiral A79FN-5EVW-R Walloven - S/c Ele
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 Washer - Top Loading
Maytag A806S Washer - Top Loading
Maytag A810 Washer - Top Loading
Maytag A8100 Washer - Top Loading
Maytag A8120 Washer - Top Loading
Maytag A8140 Washer - Top Loading
Maytag A8200 Washer - Top Loading
Maytag A8210 Washer - Top Loading
Admiral A8210PA Surface Unit - Gas
Admiral A8210PA-L Surface Unit - Gas
Admiral A8210PT-L Surface Unit - Gas
Admiral A8210PW Surface Unit - Gas
Admiral A8210PW-L Surface Unit - Gas
Admiral A8211PA Surface Unit - Gas
Admiral A8211PS Surface Unit - Gas
Admiral A8211PW Surface Unit - Gas
Maytag A8240 Washer - Top Loading
Admiral A8241RA Surface Unit - Gas
Admiral A8241RA-L Surface Unit - Gas
Admiral A8241RS Surface Unit - Gas
Admiral A8241RT-L Surface Unit - Gas
Admiral A8241RV Surface Unit - Gas
Admiral A8241RW Surface Unit - Gas
Admiral A8241RW-L Surface Unit - Gas
Admiral A8261RB Surface Unit - Gas
Admiral A8261RV Surface Unit - Gas
Admiral A82LK-3K-R Surface Unit - Gas
Admiral A82LN-3K-R Surface Unit - Gas
Admiral A82LW-2K-R Surface Unit - Gas
Admiral A82R1RV Surface Unit - Gas
Admiral A8321PA Surface Unit - Gas
Admiral A8321PS Surface Unit - Gas
Admiral A8321PW Surface Unit - Gas
Admiral A8321TA-L Surface Unit - Gas
Admiral A8321TW-L Surface Unit - Gas
Maytag A8340 Washer - Top Loading
Maytag A8420 Washer - Top Loading
Maytag A8440 Washer - Top Loading
Maytag A8500 Washer - Top Loading
Maytag A8520 Washer - Top Loading
Maytag A8600 Washer - Top Loading
Admiral A8610PA Surface Unit - Ele
Admiral A8610PS Surface Unit - Ele
Admiral A8610PV Surface Unit - Ele
Maytag A8640 Washer - Top Loading
Maytag A8650 Washer - Top Loading
Admiral A8670PB Surface Unit - Ele
Admiral A8670PV Surface Unit - Ele
Admiral A86LW-1-R Surface Unit - Ele
Maytag A8700 Washer - Top Loading
Admiral A8720PA Surface Unit - Ele
Admiral A8720PW Surface Unit - Ele
Maytag A8740 Washer - Top Loading
Maytag A8800 Washer - Top Loading
Maytag A882 Washer - Top Loading
Maytag A8820 Washer - Top Loading
Maytag A882T Washer - Top Loading
Maytag A883 Washer - Top Loading
Maytag A883T Washer - Top Loading
Maytag A884 Washer - Top Loading
Maytag A8840 Washer - Top Loading
Maytag A884T Washer - Top Loading
Admiral A88FK-1 Surface Unit - Ele
Admiral A88FK-2-R Surface Unit - Ele
Admiral A88FK-6-R Surface Unit - Ele
Admiral A88FN-2-R Surface Unit - Ele
Admiral A88FN-2R Surface Unit - Ele
Admiral A88LK-6-R Surface Unit - Ele
Admiral A88LN-6-R Surface Unit - Ele
Admiral A89L-4-R Surface Unit - Ele
Frigidaire A8LECUD2 Frg(v20) / Room Air Conditioner
Frigidaire A8MECC2 Frg(v15) / Room Air Conditioner
Frigidaire A8MECD2 Frg(v21) / Room Air Conditioner
Frigidaire A8MECUC2 Frg(v16) / Room Air Conditioner
Frigidaire A8MECUC3 Frg(v17) / Room Air Conditioner
Frigidaire A8MECUSC2 Frg(v6) / Room Air Conditioner
Frigidaire A8MECUSC3 Frg(v7) / Room Air Conditioner
Maytag A900 Washer - Top Loading
Maytag A900S Washer - Top Loading
Maytag A902 Washer - Top Loading
Maytag A906 Washer - Top Loading
Jenn-Air A910 Misc / Accessory
Admiral A9122VPV Walloven - Std Gas
Maytag A9200 Washer - Top Loading
Admiral A9211XPB Walloven - Cont Clean Gas
Admiral A9222VPV Walloven - Cont Clean Gas
Admiral A9222XPB Walloven - Cont Clean Gas
Maytag A9300 Washer - Top Loading
Maytag A9400 Washer - Top Loading
Maytag A9400S Washer - Top Loading
Maytag A9400W Washer - Top Loading
Admiral A9475VRV Walloven - S/c Gas
Admiral A9475XRB Walloven - S/c Gas
Admiral A9495VRV Range - S/c Mwave Gas
Admiral A9495XRB Range - S/c Mwave Gas
Maytag A9600 Washer - Top Loading
Maytag A9700 Washer - Top Loading
Maytag A9700S Washer - Top Loading
Maytag A9700W Washer - Top Loading
Maytag A9800 Washer - Top Loading
Admiral A9814XPB Walloven - S/c Ele
Admiral A9845VPV Walloven - S/c Ele
Admiral A9845XPB Walloven - S/c Ele
Admiral A9854VPV Walloven - S/c Ele
Admiral A9854XPB Walloven - S/c Ele
Admiral A9875VRV Walloven - S/c Ele
Admiral A9875XRB Walloven - S/c Ele
Admiral A9895VRV Walloven - S/c Mwave Ele
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer leaks on the bottoom Bummer plumber Washer Repair 1 09-09-2010 09:13 AM
Maytag Washer Leaks badodd Washer Repair 1 08-06-2010 04:07 AM
maytag washer leaks fabian g Washer Repair 2 07-02-2010 01:16 PM
Maytag Washer Leaks mriley44 Washer Repair 2 06-29-2009 12:41 PM
Maytag washer leaks smcneil Washer Repair 2 05-12-2008 12:04 PM
