Discuss
Whirlpool Washer Just Hums
 in
Washer Repair
fkukla, Please go here: http://forum.appliancepartspros.com/...just-buzz.html and answer on my question. Gene.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer Just Hums
  #11 (permalink)
Old 12-03-2008, 04:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
fkukla,
Please go here: Stopped COLD while running,Control knobs just BUZZ and answer on my question.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 05-18-2011, 09:01 PM
Junior Member
Camacho is on a distinguished road
Talking Whirlpool Washer Hums no Spinning
Hi Guys, I just finished fixing a Whirpool LXR7244PQ4. The problem was it the motor was humming but no action (spinning or washing). It did pulled water, but that was it. I took it apart (the housing) took out the pump. While doing it found a metal hard wire in the hose that comes out of the wash basket. Pulled it out and tried to start the washer again. No luck, humming again. Took out the motor and tried it outside, kicked like a mule, strong and fast. I tried to turn the basket through the coupling and it was very tight. So I took out the hose were I previously found the wire, the hose that was still connected to the washer basket and found another wire. Pulled it out and again tried to turn the basket through the coupling, and Walah! It turned. Placed the motor again and turn it on and DOUBLE WALAH! It's working again like new! I just saved over $250! The motor which I checked out was about $140 here in Puerto Rico and the Supposed Technician was another $110! Guys check out forums and site great as this one. There are a lot of rippers out there, for thing we can do ourselves. We learn and save. A new washer runs around $500 down here.
Good luck and hope this helps. camachospr@aol.com any questions I can help with.
  #13 (permalink)
Old 11-22-2011, 07:55 PM
Junior Member
cdcguy is on a distinguished road
Default Whirlpool Washer Motor Just Hums
my washer won't agitate or spin. the motor just hums. I checked the coupler and it's fine. nothing clogging the pump. I took the motor out and it just hums. won't turn. it just hums. it feels like it wants to start but doesn't. I really need some help with this. it's a Whirlpool Ultimate Care II Model#LSQ8243HQ
  #14 (permalink)
Old 11-22-2011, 08:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the capacitor (on a side of the motor). If it's good, replace the motor.
- The capacitor Part number: AP3866194
- The motor Part number: AP2907974
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSQ8243HQ0 AUTOMATIC WASHER | AppliancePartsPros.com
__________________
  #15 (permalink)
Old 11-22-2011, 09:33 PM
Junior Member
Default how to check capacitor
How can I tell if the capacitor is no good?
  #16 (permalink)
Old 11-23-2011, 05:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to have an ohmmeter to do it.
__________________
  #17 (permalink)
Old 07-16-2017, 09:53 PM
Junior Member
E-magpies is on a distinguished road
Default
same symptoms...
mine ended up being an easy fix. the return water line was plugged. cleared the line and back to normal. Lucky to have been watching the load due to a 'rug' i put in thinking it was a bad idea to begin with. So the pump/motor didn't burn out since I was able to shut it off early.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool motor hums, but will agitate asjackman Washer Repair 3 11-10-2009 04:48 AM
Whirlpool washer HUMS S. Jewell Washer Repair 1 08-20-2009 01:38 PM
Whirlpool washer - hums S. Jewell Refrigerator & Freezer Repair 0 08-18-2009 02:42 PM
Whirlpool Washer Starts Stops And Hums beverlyjean Washer Repair 1 06-02-2009 07:09 PM
Whirlpool Washer Starts Stops And Hums beverlyjean Washer Repair 1 06-02-2009 03:35 PM
