Discuss
Whirlpool Spins Intermittently
 in
Washer Repair
Hello all I posted this problem on another forum, and received some suggestions but not a definitive answer. I've also
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Spins Intermittently
  #1 (permalink)
Old 01-07-2011, 01:36 PM
Junior Member
bordercity is on a distinguished road
Default Whirlpool Spins Intermittently
Model Number: LSQ9549LW3   Brand: Whirlpool   Age: 5 - 10 years
Hello all
I posted this problem on another forum, and received some suggestions but not a definitive answer. I've also done a search, found similar problems and they were never followed up with by the OP.
I have a problem with a Whirlpool direct drive washer. The spin cycle only works intermittently. When the washer does spin, its spins fine, however about 50% of the time it doesn't spin at all. I've done a fair amount of investigating and research and have found the following.
The washer agitates properly at all times, so I ruled out the motor coupler. When the spin cycle starts but doesn't spin, the water drains fine and the pump operates. I bypassed the lid switch and the problem persists. I then removed the cabinet and monitored what was going on below. When the spin cycle works properly, the clutch spins as it is supposed to, however when the spin cycle doesn't operate properly, the clutch doesn't spin at all. I figured the problem must be in the gear case, but now I'm not so sure.
Yesterday I was home for lunch and the wife was doing a load of laundry. She yelled at me to come have a look at the washer because it was on its final spin cycle but wasn't spinning. I quickly removed the cabinet and took a look underneath, and the clutch wasn't spinning. With some effort I could move the tub by hand.
As soon as the fast spin cycle (end of full cycle) ended, I could hear the gearcase engage, and the tub moved very slightly. So this tells me that the gearcase is failing to engage when its supposed to at times. What would prevent this? Is it an internal problem with the gearcase or something else?
Could this possibly be a timer problem? I read that a worn timer may not allow the pause long enough for the gear case to engage for the spin cycle.
I appreciate all input.
Related Models
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
Whirlpool LSQ9560PW4 AUTOMATIC WASHER
Whirlpool LSQ9564JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564MQ0 AUTOMATIC WASHER
Whirlpool LSQ9565MQ0 WASHER
Whirlpool LSQ9600JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG1 AUTOMATIC WASHER
Whirlpool LSQ9600LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LW1 AUTOMATIC WASHER
Whirlpool LSQ9610JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610LG0 AUTOMATIC WASHER
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
Whirlpool LSR5100KQ0 RESIDENTIAL WASHER
Whirlpool LSR5100LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ1 AUTOMATIC WASHER
Whirlpool LSR5102LQ1 AUTOMATIC WASHER
Whirlpool LSR5121HQ0 AUTOMATIC WASHER
Whirlpool LSR5121JQ0 AUTOMATIC WASHER,
Whirlpool LSR5132AG0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AN0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AW0 DIRECT-DRIVE WASHER
Whirlpool LSR5132HQ0 AUTOMATIC WASHER
Whirlpool LSR5132HQ1 AUTOMATIC WASHER
Whirlpool LSR5132JQ0 COMPACT WASHER
Whirlpool LSR5132JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR5132JQ2 WASHER - DIRECT DRIVE
Whirlpool LSR5132PQ0 AUTOMATIC WASHER
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
Whirlpool LSR5132PQ4 AUTOMATIC WASHER
Whirlpool LSR5232DW0 AUTOMATIC WASHER
Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE
  #2 (permalink)
Old 01-08-2011, 04:37 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
If the motor is running and the pump is turning when the machine is not spinning it is probably the clutch. Look at the Sticky by Richappy at the top of this page for a discussion of clutch and brake problems.
__________________
  #3 (permalink)
Old 01-08-2011, 09:24 PM
Junior Member
Default
I'm almost sure that its not the clutch, as the clutch/clutch housing is not spinning at all when in spin cycle; ie. no engagement from the gearcase. Additionally, as mentioned in the first post, I can hear the gearcase engage (or what seems to be) at the end of the spin cycle, and the tub moves slightly. Probably because the electric motor hasn't completely stopped at this point.
  #4 (permalink)
Old 01-09-2011, 04:35 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
During spin, if the motor is running and you see the clutch housing is not turning, you either have a neutral drain clutch failure, or a bad nylon gear in the tranny. If you lift the lid, then close it and it then spins, you have a bad timer. The timer must interrupt power briefly during spin to allow the tranny neutral clutch to engage.
__________________
  #5 (permalink)
Old 01-09-2011, 08:20 AM
Junior Member
Default
Thanks richappy. Thats something I should have mentioned, but you reminded me. If I do lift the lid or interrupt the cycle with the timer (because I had the lid switch jumpered), I can hear the gearcase engage and it will start spinning. Another tech mentioned that there should be a delay between the drain and spinning, but our washer starts spinning immediately (when it works) as soon as the drain starts. So you figure the timer then?
  #6 (permalink)
Old 01-09-2011, 01:55 PM
Senior Expert
APP Volunteer
Default
You definitely have a bad timer, must interrupt power during the spin cycle to allow the tranny neutral drain clutch to engage.
__________________
  #7 (permalink)
Old 01-09-2011, 04:20 PM
Junior Member
Default
Thank you very much for your help. If I end up switching out the timer and it solves the issue, I'll let you know.
  #8 (permalink)
Old 01-12-2011, 10:00 AM
Junior Member
Default
Well, the issue with the washer is going to remain unresolved. The in-laws were in town and surprised us with a new washer. I was contemplating still repairing it, but its not worth the time and money to repair it and sell it used. Its nearly 7 years old, so I'm guessing I could only get $100-200 for it. A timer is $100. I would have liked to solve the issue, but it would be silly to put any money into it.
Thanks all for your help.
  #9 (permalink)
Old 03-08-2015, 06:43 PM
clj clj is offline
Junior Member
clj is on a distinguished road
Default intermittent spin
I have the exact same problem to a T.
already replaced the clutch and that didn't do it,
if i find a timer cheap ill swap it and let you know if that was it.
  #10 (permalink)
Old 03-13-2015, 03:29 PM
clj clj is offline
Junior Member
Default
it was indeed the timer. As mentioned above aparently if the timer wears out it can try to start the spin before the motor has spun down and stopped all the way from the rinse pumping, and that prevents something from engaging, that is why the spin starts working if you open the lid to inspect it when its not working and then reclose it.(because everything has stopped spinning) ~85 bucks for a time and a super easy install.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool spins agitates intermittently, smells tbyers31 Washer Repair 9 09-26-2009 03:54 PM
whirlpool drying intermittently nicracing Dryer Repair 1 08-03-2009 08:42 PM
Drum spins intermittently rnhowie Dryer Repair 9 05-25-2009 05:02 PM
Kenmore Spins Intermittently Philn Washer Repair 5 01-26-2009 05:40 AM
Washer spins intermittently wardtrevor Washer Repair 1 03-30-2008 04:07 AM
