attempting to install a water inlet valve -- but cannot figure out how to remove cabinet
If you will insert a thin blade or putty knife under the end caps from the front you can release the clips that hold the console on. It will flip up, and then you can disconnect the lid switch, pop out the clips that old the cabinet on and it will come forward and come off.
