Discuss
Kenmore washer does not agitate/spin
 in
Washer Repair
Our Kenmore washer does not agitate/spin. Front door indicator shows door is locked (door has been veified to be locked).
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer does not agitate/spin
  #1 (permalink)
Old 11-28-2008, 11:35 AM
Junior Member
FLAD is on a distinguished road
Unhappy Kenmore washer does not agitate/spin
Model Number: 417.29942991   Brand: Kenmore   Age: 5 - 10 years
Our Kenmore washer does not agitate/spin. Front door indicator shows door is locked (door has been veified to be locked). Water comes in/out. Timer goes thru cycle. Just no agitation/spin. What are the possible troublshooting steps or causes?
Model number is 417.29942991
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
  #2 (permalink)
Old 11-28-2008, 04:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the door switches. The model number you posted does not come up.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-12-2008, 08:08 AM
Junior Member
Thumbs up Problem solved
Model number is 417.29042991
Found when I took the bottom panel off there was taped in the inside of the washer detailed troubleshooting instructions. I followed the instructions for "motor does not work". This involved taking off various connectors and measuring voltages, etc. [connections to the speed control board] Everything measured OK which was puzzling. As recommended by the troubleshooting guide I took off connections to the timer and measured there. Everything looked OK. I reassembled and the unit started working so I put it back together thinking a bad connection (wires/connectors looked OK visually). Washer worked for 2 weeks then the high spin mode on all 3 wash modes (normal, delicates, etc) stop working. Looking at the circuit diagram for the 3 modes noticed that low out flow might cause the high spin mode to be inhibited. Decided to disassemble the plumbing going to/from the drain pump. Discovered $2.05 in coins in the plumbling leading up to the drain pump and most importantly I found a nickle lodged in the outflow portion blocking a portion of the outflow. Removed all the change and the nickle lodged in the outflow. Flushed out teh drain hose for good measure. Washer is now re-assembled. Have done 4 loads so far and the high spin mode is working!
  #4 (permalink)
Old 12-12-2008, 03:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Good job. We are glad you were able to fix it. Happy Holidays!
__________________
  #5 (permalink)
Old 01-09-2013, 10:06 AM
Junior Member
johnjrding is on a distinguished road
Default 417.29042991 timer runs, fills drains but no action
My symptoms are the same as the thread I followed. But I bought the machine from a repair shop in 2000 and the instructions are missing. I installed the door side of the lock/switch mechanism with same resulte. I can clearly hear the timer trying to change rotation and functions. I just took $1.50 out of the pump inlet(you could get $10.00 in the sump tube) but no change in function. I can unplug the motor harness but not having a diagram I don't know what to check. Could you direct me too or send a diagram for this test. This is a great service you guys provide! Thank you,
Quote:
  #6 (permalink)
Old 01-10-2013, 03:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
You may want to start the troubleshooting from testing the door lock. Remove the door lock and measure the wax motor resistance. The normal reading suppose to be about 1500 Ohms.
- The door lock assembly Part number: 131763202
If there is nothing wrong , follow the instructions from the attached file and post the results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Kenmore washer will not agitate or spin Terri1961 Washer Repair 5 01-25-2010 05:31 AM
Kenmore washer will agitate but will nto spin and drain water thediva805 Washer Repair 4 01-27-2009 12:26 PM
Kenmore top-load washer does not spin or agitate HarryD Washer Repair 6 09-19-2008 02:57 PM
Kenmore washer won't spin, agitate, or go through cycles asnapp Washer Repair 10 08-26-2008 06:53 PM
