| » washer fills then starts spinning instead of agitating |
Model Number: WNSR4100Y1WW Brand: GE Age: 1 - 5 years
Washer fills then starts spinning instead of agitating. Water drains if you put it on spin cycle. Did not try letting it go through whole cycle. Any suggestions? Thanks
Ads By Google Related Models Last edited by hgscout : 01-04-2011 at 08:14 AM. |
The brakes are bad and the only way to repair this is to replace the transmission. The transmission is somewhat expensive but if you replace it yourself it isn’t too bad. This page will help with replacing the transmission should you decide to do so. GE Washer Disassembly Guide
The washers made during the time yours was made had a lot of problems with the brake bearing which causes the problem you are having. We use to be able to replace the bearings but they discontinued the bearings and now you have to replace the transmission. |
| Display Modes | |
| Washer - not agitating or spinning | char2234 | Washer Repair | 0 | 06-30-2010 12:16 PM |
| washer not spinning or agitating but does everything else | albarran61483 | Washer Repair | 5 | 03-29-2010 06:22 AM |
| washer not spinning or agitating again. | bounette77 | Washer Repair | 2 | 02-17-2010 11:00 AM |
| Washer not spinning or agitating | LaraandJody | Washer Repair | 0 | 05-24-2009 04:01 PM |
| Washer starts agitating same time it's filling up | hrscales | Washer Repair | 3 | 04-03-2009 05:27 PM |
