Discuss
should the drum turn by hand?
 in
Washer Repair
I have an Estate washer, direct drive and needed to replace the motor coupler. Not knowing anything about washers, I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » should the drum turn by hand?
  #1 (permalink)
Old 11-28-2008, 12:33 PM
nubenow nubenow is offline
Junior Member
nubenow is on a distinguished road
Default should the drum turn by hand?
Brand: -brand-   Age: Less than 1 year
I have an Estate washer, direct drive and needed to replace the motor coupler. Not knowing anything about washers, I lowered the gearbox by mistake before I realised it wasn't needed. I replaced the coupler with no problem, when I went to bolt the gearbox back in place, it didn't want to go all the way on the mounting dowels.
After fiddling with it it did go and I re-assembled everything. Now the drum will not turn by hand, and before I power it up and risk breaking something, I wanted to know if not be able to turn the drum is normal, or not?
  #2 (permalink)
Old 11-28-2008, 12:56 PM
AaronG AaronG is offline
Junior Member
AaronG is on a distinguished road
Default
No a Estate washer you should not be able to turn the drum by hand.
  #3 (permalink)
Old 11-28-2008, 02:24 PM
Junior Member
Default
Thanks, how about being able to move the agitator? It will turn freely clockwise, but anti clockwise it is locked solid. Is this correct?
  #4 (permalink)
Old 11-28-2008, 05:42 PM
Junior Member
Default
I have removed the agitator, which as it happens, only moves freely the one way and not the other.
However, I think that I should still be able to rotate it both ways once it's connected, as all in essence you are doing is rotating the gearbox and the motore..........or am I wrong?
  #5 (permalink)
Old 12-01-2008, 05:45 AM
Junior Member
Default
no it should turn in 1 direction only there are clutches called "Dogs" that will not alow it. Also the bottem part should not turn
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
should it turn by hand nubenow Washer Repair 1 12-01-2008 06:52 PM
upper agitator does not turn except by hand rons45cal Washer Repair 0 11-23-2008 11:29 AM
drum won't turn grannyb2x Dryer Repair 3 09-19-2008 09:05 AM
Drum will not turn David Rivera Dryer Repair 1 07-11-2008 02:03 PM
drum won't turn herman Dishwasher Repair 0 05-23-2008 11:50 AM
