Rank:: Member
Hi, Model NO. MAV7757AWW (P) Serial NO. 16667853CC (S) Style (Y) 7909215 I just replaced the upper bearing and the seal nut. The washer previously leaked causing the bearing to go bad. I uploaded a picture. It only seems to leak when it goes into the spin cycle. You can see it leaking between the bottom of the upper tub support and the top of the transmission. Any insight or suggestions would be much appreciated. Thank you very much Mike ensignia attached the following image(s):
