Discuss
Whirlpool duet leaking from detergent dispenser
 in
Washer Repair
Originally Posted by tom@creeksidetec.com my leak is a small amount of water below the drawer side of the washer not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool duet leaking from detergent dispenser
  #11 (permalink)
Old 09-05-2013, 06:17 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by tom@creeksidetec.com View Post
my leak is a small amount of water below the drawer side of the washer not sure what to do
Tom, There are two things to check, right off. First remove the complete drawer assembly and check for debris(undissolved detergent, bottle cap seals, etc). If all's OK, remove the top panel and check the fill hose from the dispenser to the tub, make sure it's not clogged with the same debris.
Occasionally, an article can get between the tubs and get caught on the end of the fill hose, you may need to carefully remove the hose from the tub and check for an article.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #12 (permalink)
Old 10-16-2013, 03:35 PM
Junior Member
Jayblade is on a distinguished road
Default
You guys rock! No technical skill and fixed it in under 30 minutes. If you're ever in winnipeg beer is on me!
  #13 (permalink)
Old 10-17-2013, 06:13 AM
Senior Expert
Default
Quote:
Jayblade,
We are glad we could help you out. We hope all stays well .
Thanks Again,
__________________
Joe M. APP TEAM
  #14 (permalink)
Old 11-11-2013, 07:32 AM
Junior Member
bobby52375 is on a distinguished road
Default
Does anyone know how to replace the dispenser hose to the tub? I have a slice in my hose, and am worried about inserting a new hose into the tub.....
  #15 (permalink)
Old 11-11-2013, 08:50 AM
Senior Expert
Default
Quote:
Bobby, Presumably you mean the tub top shower hose
Part number: AP3919176
There's nothing to be worrysome about installing the new hose, or removing the original. It'll be easier if you disconnect the end of the hose from the dispenser. Then grasp the hose as close to the tub as possible, and pinch it together and pull up and out on the hose. You need to make sure you get the whole assembly removed from the tub opening, and don't tear or loose the retainer end of the hose inside the tub. A dab of liquid detergent on the rubber flange will hwlp to make it easier to install the hose, but just reverse the process, pinch the hose and insert the flange and work it until it seats and seals, then attach the end of the hose to the dispenser, try to keep any kinks or twists from developping in the hose. Good Luck.
__________________
Joe M. APP TEAM
  #16 (permalink)
Old 12-31-2014, 01:57 PM
Junior Member
dlrepp is on a distinguished road
Default uneven
I was wondering how much of a tilt would cause this problem. The back right hand corner is about 1 inch higher than the front left corner where the detergent dispenser is. I haven't found anything blocking yet.
  #17 (permalink)
Old 01-02-2015, 07:26 AM
Senior Expert
Default
Quote:
Dlrepp, Under certain installations (basements garages etc.) that can happen. As long as the washer cabinet is level, in both directions you're OK.
If the washer is higher in the back, it could cause water to flow improperly and flow out the front of the dispenser, or accumulate and cause a problem.
Remember to remove the dispenser drawer, and check for any debris that may have accumulated under the drawer, and may be blocking the tub inlet hose.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet leaking kswehman Washer Repair 2 03-05-2010 09:59 AM
Whirlpool Dishwasher Detergent Dispenser Spring posterman Dishwasher Repair 2 02-28-2010 07:21 AM
Whirlpool detergent dispenser thomas196444 Dishwasher Repair 0 09-09-2009 05:40 AM
Leaking Whirlpool Duet termigator Washer Repair 0 04-23-2009 04:23 PM
Whirlpool Duet Sports leaking from under door martinez Washer Repair 1 03-22-2009 12:35 PM
