Sears HE2plus front loader. No high speed spin with normal load in it. Will spin ok empty or with a light load.Ran diagnostics and it will not ramp up to maximum speed on last part of test as called for. It will not even tumble on that last part. Had flashed f-34 code but not sure if that is relevant. The main control or ccu was replaced but problem not cured.
The likely culprit is the motor control unit. See if there is a tech sheet under the top or inside the lower service panel that will allow you to test it. If not, try replacing it and see what happens. If you buy from this site and the part does not fix the problem you can return it, see the returns policy for details.
