My washer suddenly stopped working. it is a front load whilrpool washer bought in dec 2008 adn the model # is WFW84OOTW02. It is not tumbling, agitating or spinning or washing. i hear some noise when i start/power on the washer.
your help is greatly appreciated.
Ritesh
Look inside the lower service panel, or under the top cover and you should find some tech notes that will allow you to put it into a diagnosis mode and generate error codes. That should help you diagnose the problem.
hi, can you please explain how to locate the lower service panel that you are talking about and the explain about setting it to the diagnosis mode. your help is greatly appreciated. Ritesh
