Discuss
Water won't stop filling up
 in
Washer Repair
[FONT='Verdana','sans-serif']Wash does not work at all on any cycle modes. Model: Whirlpool Roper; Part No. 3956970; 5 years old. Water
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water won't stop filling up
  #1 (permalink)
Old 01-02-2011, 12:55 PM
Junior Member
Clifton Guo is on a distinguished road
Default Water won't stop filling up
Model Number: Roper   Brand: Whirlpool   Age: 1 - 5 years
[FONT='Verdana','sans-serif']Wash does not work at all on any cycle modes. Model: Whirlpool Roper; Part No. 3956970; 5 years old. Water fills up the washer, even I chose Small on Water Level and it won’t stop. So it will over flow. I manually stopped the washer then turned the knob to Rinse. It will drain the water out. I tried all different cycle modes, but got the same results. Any help will be greatly appreciated.[/font]
[FONT='Verdana','sans-serif']Thank you![/font]
Ads By Google
Related Models
Frigidaire RP13M2WS2B Gib(v4) / Top Mount Refrigerator
Frigidaire RP13M2WS2C Gib(v5) / Top Mount Refrigerator
Frigidaire RP13M2WS2D Gib(v6) / Top Mount Refrigerator
Amana RR Mwave - Family Size (60 Hz)
Amana RR-1 Range - S/c S/i Ddraft Gas
Amana RR-10 Mwave - Family Size (60 Hz)
Amana RR-1000 Mwave - Cntrtp / Stand Alone
Amana RR-1010 Mwave - Cntrtp / Stand Alone
Amana RR-10A Mwave - Cntrtp / Stand Alone
Amana RR-1110 Mwave - Family Size (60 Hz)
Amana RR-1225 Mwave - Cntrtp / Stand Alone
Amana RR-3H Range - S/c S/i Ddraft Gas
Amana RR-4 Range - S/c S/i Ddraft Gas
Amana RR-4D Range - S/c S/i Ddraft Gas
Amana RR-4DW Range - S/c S/i Ddraft Gas
Amana RR-5B Mwave - Cntrtp / Stand Alone
Amana RR-6 Mwave - Family Size (60 Hz)
Amana RR-7 Range - S/c S/i Ddraft Gas
Amana RR-700 Range - S/c S/i Ddraft Gas
Amana RR-7A Mwave - Family Size (60 Hz)
Amana RR-7B Mwave - Cntrtp / Stand Alone
Amana RR-7D Mwave - Family Size (60 Hz)
Amana RR-7DA Mwave - Family Size (60 Hz)
Amana RR-8 Mwave - Family Size (60 Hz)
Amana RR-800 Mwave - Cntrtp / Stand Alone
Amana RR-810 Mwave - Cntrtp / Stand Alone
Amana RR-820 Mwave - Cntrtp / Stand Alone
Amana RR-8A Mwave - Family Size (60 Hz)
Amana RR-8B Mwave - Family Size (60 Hz)
Amana RR-8T Mwave - Cntrtp / Stand Alone
Amana RR-8TC Mwave - Cntrtp / Stand Alone
Amana RR-9 Range - S/c S/i Ddraft Gas
Amana RR-900 Mwave - Cntrtp / Stand Alone
Amana RR-910 Range - S/c S/i Ddraft Gas
Amana RR-9T Mwave - Family Size (60 Hz)
Amana RR-9TA Mwave - Family Size (60 Hz)
Amana RR-9TB Mwave - Cntrtp / Stand Alone
Amana RR-II Range - S/c S/i Ddraft Gas
Amana RR1020 Mwave - Cntrtp / Stand Alone
Amana RR1220 Mwave - Cntrtp / Stand Alone
Amana RR2 Mwave - Cntrtp / Stand Alone
Amana RR510 Mwave - Cntrtp / Stand Alone
Amana RR510A Mwave - Cntrtp / Stand Alone
Amana RR52 Mwave - Family Size (60 Hz)
Amana RR54 Mwave - Family Size (60 Hz)
Amana RR54D Mwave - Cntrtp / Stand Alone
Amana RR56 Mwave - Cntrtp / Stand Alone
Amana RR57D Mwave - Cntrtp / Stand Alone
Amana RR59T Mwave - Cntrtp / Stand Alone
Amana RR6W Mwave - Cntrtp / Stand Alone
Amana RR7 Mwave - Cntrtp / Stand Alone
Amana RR720 Mwave - Cntrtp / Stand Alone
Amana RR9 Mwave - Cntrtp / Stand Alone
Amana RR920 Mwave - Cntrtp / Stand Alone
Amana RRC57D Mwave - Cntrtp / Stand Alone
Amana RRH-10 Mwave - Family Size (60 Hz)
Whirlpool RRH260
Whirlpool RRH261
Whirlpool RRH262
Whirlpool RRH266
Amana RRL-10A Mwave - Family Size (60 Hz)
Amana RRL-10C Mwave - Cntrtp / Stand Alone
Amana RRL-10TD Mwave - Family Size (60 Hz)
Amana RRL-10XA Mwave - Family Size (60 Hz)
Amana RRL-5C Mwave - Family Size (60 Hz)
Amana RRL-5D Mwave - Cntrtp / Stand Alone
  #2 (permalink)
Old 01-02-2011, 01:51 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Here the gig!!! If the water shuts off, when you hit the timer knob to off, you need a water level switch. If you have to shut the water off, behind the washer, you need a water valve. But before you order anything, flip back the control panel, and make sure the clear plastic hose did not fasll off the water level switch. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water does not stop filling laird Washer Repair 0 05-12-2010 05:41 PM
Won't stop filling with water ToniB Washer Repair 0 04-21-2010 03:23 AM
Water will not stop filling tkonrad Washer Repair 3 11-15-2009 08:12 PM
water won't stop filling aaacc Washer Repair 3 10-26-2009 09:50 AM
Will not stop filling with water. Kazeke Washer Repair 1 10-16-2009 04:31 PM
