I have a stackable washer and dryer Ser# S701639 P/N 221870022 D26M9402 Front loader washer bearing on the rear of the tub directly behind the drun pulley is shot. How do I replace this bearing. Can it be removed from the rear or do I need to split the tub. Thanks for any info. maxcohen@live.com
The tub has to be disassembled and this is not an easy job. The model number you posted is incorrect. Verify and repost it please.
