Discuss
Kenmore washer will not fill
 in
Washer Repair
Strange problem with my Kenmore Super Capacity 3.5 front load washer. When I moved into this home the washer worked
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer will not fill
  #1 (permalink)
Old 01-01-2011, 08:18 AM
Junior Member
tconley is on a distinguished road
Default Kenmore washer will not fill
Model Number: 41744082400   Brand: Kenmore   Age: 1 - 5 years
When I moved into this home the washer worked on on certain temp settings, but that was fine. Now it won't work on any settings. When I start the the machine it doesn't fill, just clicks.
Funny thing though, when I put it on delayed start (like 30 min), when it finally starts, the water DOES try to fill. I hear the water rush into the inlet valve, but then it stops abruptly and a trickle of water comes into the tank. It does this repeatedly until I cancel the wash.
Water pressure is good, so I assume it would be the pressure switch? I checked the hose connecting the switch to the tank -- all clear.
Any thoughts? Especially on why it would act differently when put on delayed start vs regular start??
Thanks!
Related Models
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
Kenmore 41783142300 DRYER
Kenmore 41784042500 DRYER
Kenmore 41784052500 DRYER
Kenmore 41784072300 DRYER
Kenmore 41784082500 DRYER
Kenmore 41784092500 DRYER
Kenmore 41784130000 DRYER
Kenmore 41784131000 DRYER
Kenmore 41784132000 DRYER
Kenmore 41784152500 DRYER
Kenmore 41784252500 DRYER
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41787042700 DRYER
Kenmore 41788042700 DRYER
Kenmore 41788052700 DRYER
Kenmore 41788056700 DRYER
Kenmore 41788076700 DRYER
Kenmore 41788988100 ELECTRIC DRYER
Kenmore 41788988800 ELECTRIC DRYER
Kenmore 41788989100 GAS DRYER
Kenmore 41788989800 GAS DRYER
Kenmore 41789090100 WASHER DRYER COMBINATION
Kenmore 41789090110 COMBINATION WASHER-DRYER
Kenmore 41789090200 WASHER DRYER COMBINATION
Kenmore 41789090210 COMBINATION WASHER-DRYER
Kenmore 41789090400 WASHER DRYER COMBINATION
Kenmore 41789090410 COMBINATION WASHER-DRYER
Kenmore 41789090600 WASHER DRYER COMBINATION
Kenmore 41789090610 COMBINATION WASHER-DRYER
Kenmore 41789090800 WASHER DRYER COMBINATION
Kenmore 41789090810 COMBINATION WASHER-DRYER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
Kenmore 41789195110 COMBINATION WASHER/DRYER
Kenmore 41789195120 COMBINATION WASHER/DRYER
Kenmore 41789195600 COMBINATION WASHER/DRYER
Kenmore 41789195610 COMBINATION WASHER/DRYER
Kenmore 41789195620 COMBINATION WASHER/DRYER
Kenmore 41789195800 COMBINATION WASHER/DRYER
  #2 (permalink)
Old 01-03-2011, 09:56 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
This machine has built in diagnostics, and you can learn how to activate them by getting the tech notes that should be inside the lower service panel. See if you can generate an error code which should tell you where to look for the problem. The likely area is the main control.
__________________
  #3 (permalink)
Old 01-04-2011, 07:13 AM
Junior Member
Default Got Error 57
Thanks for the tip!
Found the manual and I get E57...which is "High Current on Inverter". I manual manual mentions removing the belt and checking the motor. Supposedly it's either a bad motor or bad main control board as you mentioned. Not sure how difficult testing the motor is or if I should just try replacing the main control board first....
  #4 (permalink)
Old 01-04-2011, 01:49 PM
Senior Expert
APP Volunteer
Default
The tech notes should show you how to test the motor using a meter, but it is far more likely that the speed control board, not the main control board is the problem. I would start by changing it out. If you purchase from this site and it does not repair the problem you can return it, see the returns policy for details (those of us who respond on this site are volunteers and not associated with the parts operations of APP).
__________________
  #5 (permalink)
Old 01-06-2011, 11:06 AM
Junior Member
Default
Thanks for the response.
Found a "control board" on the site.
Part Details - FRIGIDAIRE CONTROL BOARD, part number: AP3891780
Is this the same as "speed control board"?
  #6 (permalink)
Old 01-06-2011, 02:20 PM
Senior Expert
APP Volunteer
Default
Yep, that should be the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore front load washer won't continue to fill. clearwater1950 Washer Repair 2 06-02-2011 05:08 PM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Washer will not fill after replacing fill valve toddf Washer Repair 1 12-03-2010 12:39 PM
Kenmore Washer will fill/drain,but not agitate/spin help! Washer Repair 1 02-02-2009 06:43 PM
kenmore washer that wont fill shawn1991 Washer Repair 4 04-05-2008 09:33 PM
