Discuss
Roper Washer Direct Drive
 in
Washer Repair
It will fill with water, and not leak : ) it was leaking really bad so we replaced the water
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper Washer Direct Drive
  #1 (permalink)
Old 11-27-2008, 12:18 PM
Junior Member
Jennburch is on a distinguished road
Default Roper Washer Direct Drive
Brand: Roper   Age: 5 - 10 years
It will fill with water, and not leak : ) it was leaking really bad so we replaced the water pump. Now when we turn it on it will not agitate or spin, it just fills. it makes a humming noise that sounds like it is trying to work but it doesn't... HELP!
We checked the couplings, the brake and the clutch all are fine. I don't know what it could be
  #2 (permalink)
Old 11-28-2008, 04:34 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Check the lid switch.
nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 11-28-2008, 05:57 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Check the pump for blockage. Pull the pump and check, if ok, turn the motor shaft with an adjustable wrench to see if there is a jam. If ok, check the motor connector for missing wire/bent bin.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
finding a direct drive washer NCjohn Washer Repair 9 09-02-2010 05:47 PM
direct drive washer cecil tillery Washer Repair 1 08-17-2009 06:35 PM
replacing drive coupleing on Whirlpool direct drive washer bbuck222 Washer Repair 2 08-06-2009 07:34 AM
Direct drive washer brake yurman Washer Repair 1 08-02-2009 04:35 AM
Direct Drive Washer JNOLES Washer Repair 1 09-19-2007 04:24 PM
