Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Roper Washer Direct Drive (http://forum.appliancepartspros.com/washer-repair/15729-roper-washer-direct-drive.html)
Jennburch 11-27-2008 12:18 PM
It will fill with water, and not leak : ) it was leaking really bad so we replaced the water pump. Now when we turn it on it will not agitate or spin, it just fills. it makes a humming noise that sounds like it is trying to work but it doesn't... HELP!:confused:
We checked the couplings, the brake and the clutch all are fine. I don't know what it could be
libertyappl 11-28-2008 04:34 AM
Check the lid switch.
nat
richappy 11-28-2008 05:57 AM
Check the pump for blockage. Pull the pump and check, if ok, turn the motor shaft with an adjustable wrench to see if there is a jam. If ok, check the motor connector for missing wire/bent bin.
