It is my friends washer.
Has no power, when plugged into a working outlet.
There is power that gets to the board, however that is it.
Any recommendations ? How to check? What to check?
I'm skilled with a Volt meter, as I work in the 12v industry pretty often. Mechanically able, especially with common sense on how to dissasemble/reassemble items.
