The water will not stop and will run out of the machine if left alone. Could this be the reason?: I had the machine laid down on it's face to work under just before this problem started. Is that clear hose will not function properly if the machine is moved from the upright position? That clear hose have to be primed? Is that OK to lay down a washing machine? Thanks for any help! I would like to fix this so the machine could be used during the New Year day.
Never mind. I found the clear hose that came off the nipple of one of the two pressure switches on the top of the unit. Yippee! Happy New Year!!
