The washer, when set on the "Extra Large" load size will not agitate during the wash cycle, however, it does spin and drain at this load setting. When selecting a smaller load size, the washer works during all cycles.
Ideas on what may be causing this and possible fixes would be appreciated. Thanks.
I think the most likely problem is the water level switch, which tells the timer to start agitating once the tub is filled.
Try replacing it and see if that fixes things.
Thank you, I'll give it a try. Originally Posted by: sidfink43 I think the most likely problem is the water level switch, which tells the timer to start agitating once the tub is filled.
