Discuss
spin stops early; coupler does turn basket; clutch spins then stops
 in
Washer Repair
My direct-drive washer agitates just fine. Then when it starts to spin, the trouble starts. It spins fine if completely
Appliance Repair Forum > Appliance Repair Help > Washer Repair » spin stops early; coupler does turn basket; clutch spins then stops
  #1 (permalink)
Old 12-30-2010, 09:04 AM
Junior Member
rambelmont is on a distinguished road
Default spin stops early; coupler does turn basket; clutch spins then stops
Model Number: 1110.92591200   Brand: Kenmore   Age: 5 - 10 years
My direct-drive washer agitates just fine. Then when it starts to spin, the trouble starts. It spins fine if completely empty. When it has any weight in it, it starts to spin then stops. If I try it again immediately, nothing happens. But if I wait some time, and spin the dial again, it repeats: starts to spin then stops.
I tried your "sticky" test -- spinning the coupler does spin the basket.
I also tested the spin cycle with the cabinet off: the clutch spins at the start and then stops. Also the motor seems to make a noise like it is trying to get the spin going, but then stops.
I am beginning to think that the spin shuts off because the motor over-heats. But that leaves the question why it is overheating?
I read in a repair manual that if the clutch spins, the problem is not in the gear case/transmission. But what if the clutch starts to spin and then stops? Does that still mean it is not the transmission?
What can I try to locate the problem? The washer is now in the middle of my kitchen with the outside cabinet up on the countertop so I have enough room to get to the sink and stove!
Thank you for your help
Related Models
Amana 11100.A MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 1111WAW RANGE- F/S STD GAS
Magic Chef 1111WAW-L RANGE- F/S STD GAS
Magic Chef 1111WRA RANGE- F/S STD GAS
Magic Chef 1111WRW RANGE- F/S STD GAS
Hoover 1112
Hoover 1113
Roper 1116*0A GAS COOKTOP
Roper 1116W0A GAS COOKTOP
Hoover 1118
Hoover 1120
Hoover 1122
Amana 1125A ROOM AIR CONDITIONER
Amana 1125R ROOM AIR CONDITIONER
Amana 113-3EW ROOM AIR CONDITIONER
Amana 113-3HEW ROOM AIR CONDITIONER
Amana 113-3N ROOM AIR CONDITIONER
Amana 113-3NE ROOM AIR CONDITIONER
Amana 113-3NHE ROOM AIR CONDITIONER
Amana 113-3W ROOM AIR CONDITIONER
Amana 113-5N ROOM AIR CONDITIONER
Amana 113-5NE ROOM AIR CONDITIONER
Amana 113-5NH ROOM AIR CONDITIONER
Hoover 1130
Amana 1130.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1130.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1131.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1131.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 1131.101 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1132
Amana 1132.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 1133HEW ROOM AIR CONDITIONER
Amana 1133W ROOM AIR CONDITIONER
Hoover 1136
Amana 1139.C MWAVE - FAMILY SIZE (60 HZ)
Amana 1139.D MWAVE - FAMILY SIZE (60 HZ)
Amana 11390.A MWAVE - FAMILY SIZE (60 HZ)
Amana 11390.B MWAVE - FAMILY SIZE (60 HZ)
Amana 113W-3EW ROOM AIR CONDITIONER
Amana 113W-3N ROOM AIR CONDITIONER
Amana 113W-3NE ROOM AIR CONDITIONER
Amana 113W-3W ROOM AIR CONDITIONER
Hoover 1140
Hoover 1142
Amana 1144.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1145.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1145.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1146.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1146.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 1146.101 MWAVE - FAMILY SIZE (60 HZ)
Amana 1147.001 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1148
Amana 1148.002 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1149
Amana 1150.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1150.002 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1151
Admiral 1151AA-36 SURFACE UNIT- ELE
Admiral 1151AA-36G SURFACE UNIT- ELE
Admiral 1151AD-30 SURFACE UNIT- ELE
Admiral 1151AD-36 SURFACE UNIT- ELE
Admiral 1151AH-30 SURFACE UNIT- ELE
Admiral 1151AH-36G SURFACE UNIT- ELE
Admiral 1151AJ-30 SURFACE UNIT- ELE
Admiral 1151AL-30 SURFACE UNIT- ELE
Admiral 1151AL-36G SURFACE UNIT- ELE
Admiral 1151WA-36 SURFACE UNIT- ELE
Admiral 1151WA-36G SURFACE UNIT- ELE
Admiral 1151WD-30 SURFACE UNIT- ELE
Admiral 1151WD-36 SURFACE UNIT- ELE
Admiral 1151WH-30 SURFACE UNIT- ELE
Admiral 1151WH-36G SURFACE UNIT- ELE
Admiral 1151WJ-30 SURFACE UNIT- ELE
Admiral 1151WL-30 SURFACE UNIT- ELE
Admiral 1151WL-36G SURFACE UNIT- ELE
Hoover 1152
Hoover 1153
Hoover 1157
Hoover 1159
Hoover 1170
Admiral 1171AF-36GK SURFACE UNIT- GAS
Admiral 1171AF-36K SURFACE UNIT- GAS
Admiral 1171AH-30 SURFACE UNIT- GAS
Admiral 1171AH-30K SURFACE UNIT- GAS
Admiral 1171AH-36GK SURFACE UNIT- GAS
Admiral 1171AJ-30 SURFACE UNIT- GAS
Admiral 1171AJ-30K SURFACE UNIT- GAS
Admiral 1171AJ-36GK SURFACE UNIT- GAS
Admiral 1171AK-36GK SURFACE UNIT- GAS
Admiral 1171AL-30 SURFACE UNIT- GAS
Admiral 1171AL-30K SURFACE UNIT- GAS
Admiral 1171AL-36GK SURFACE UNIT- GAS
Admiral 1171WF-36GK SURFACE UNIT- GAS
Admiral 1171WF-36K SURFACE UNIT- GAS
Admiral 1171WH-30 SURFACE UNIT- GAS
Admiral 1171WH-30K SURFACE UNIT- GAS
Admiral 1171WH-36GK SURFACE UNIT- GAS
Admiral 1171WJ-30 SURFACE UNIT- GAS
Admiral 1171WJ-30K SURFACE UNIT- GAS
Admiral 1171WJ-36GK SURFACE UNIT- GAS
Admiral 1171WK-36GK SURFACE UNIT- GAS
Admiral 1171WL-30 SURFACE UNIT- GAS
Admiral 1171WL-30K SURFACE UNIT- GAS
Admiral 1171WL-36GK SURFACE UNIT- GAS
Hoover 1172
Admiral 1172AJ-30K SURFACE UNIT- GAS
Admiral 1172AL-30K SURFACE UNIT- GAS
Admiral 1172WJ-30K SURFACE UNIT- GAS
Admiral 1172WL-30K SURFACE UNIT- GAS
Hoover 1174
Hoover 1176
Roper 1176*0A GAS COOKTOP
Roper 1176W0A GAS COOKTOP
Hoover 1178
Roper 1195*1A GAS COOKTOP
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer spins & heat starts then stops tmenture Dryer Repair 4 10-28-2010 09:32 AM
Washer Spins slowly stops and restarts eegone Washer Repair 1 03-16-2010 04:36 AM
GE Washer spins then stops Offroader25 Washer Repair 3 10-09-2008 05:23 PM
Stops early, now only runs on 1 cycle Help_ Repairs Dryer Repair 1 08-14-2008 04:41 AM
New clutch and basket drive - still no spin jbrad4ou Washer Repair 9 05-09-2008 03:47 AM
