| » frigidaire washer belt does not fit |
Model Number: FWT647GHS0 Brand: Frigidaire Age: 1 - 5 years
Help!! We are trying to replce the drive belt but the replacement belt seems way too tight. Part # is 134051000. Don't see any adjustment or tensioner. Have tried two belts, same part number, same result.
Quote:
Yes, a new drive belt looks and measures smaller than the original, And can be a hard or frustrating process. Drive belt: The drive belt (6 rib flat Poly-V) is used to transmit power adjustments unnecessaryfrom the motor pulley to the tub. The belt is constructed of a material that stretches which makes belt tension It's easiest if you, install the belt on the motor pulley, then "roll" it onto the drum pulley as you slowly turn the drum pulley. Once the belt is on the pulley, turn the drum a few rotations and recheck the alignment of the belt and pulleys. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Frigidaire washer won't spin-squeals and smokes, belt slipping? | paradiseranch04 | Washer Repair | 0 | 03-22-2010 09:29 AM |
| Frigidaire washer belt tensioner | Jason H | Washer Repair | 2 | 11-04-2009 05:26 PM |
| FRIGIDAIRE Washer - belt change procedure? | gbir | Washer Repair | 1 | 09-24-2009 03:57 PM |
| Frigidaire washer belt rips to shreds | frontline | Washer Repair | 3 | 09-03-2009 12:07 PM |
| How do you install belt on frigidaire washer | gmeunier | Washer Repair | 1 | 11-14-2008 01:55 PM |
