My washer will not advance cycles. It will fill, agitate, rinse and spin if set manually. Also, once it is set manually, it continuously runs in the cycle set until manually advanced.
Is this something that I can repair or should i call a professional?
Thanks dclayton
Most probably a bad timer, you will need model # to order on this site.
Model number is RAS8333PQ0. Is this an easy fix? Thanks
