Discuss
Kenmore 90 series Washer won't agitate or spin but sounds like it is trying to.
 in
Washer Repair
My washer fills and drains fine, but it won't agitate or spin. It makes a grinding noise and looks like
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 90 series Washer won't agitate or spin but sounds like it is trying to.
  #1 (permalink)
Old 11-25-2008, 11:43 AM
Junior Member
bec777@charter.net is on a distinguished road
Default Kenmore 90 series Washer won't agitate or spin but sounds like it is trying to.
Model Number: 22902   Brand: Kenmore   Age: 5 - 10 years
My washer fills and drains fine, but it won't agitate or spin. It makes a grinding noise and looks like it is attempting to agitate. Looked at repair help and suggested dog and cam problem and to remove agitator to access those parts. It suggests to remove the cap and remove a 7/16 bolt. bolt head under cap doesn't exist or bolt is upside down so no way to remove. there is a mylar piece that appears to screw on to that bolt. please help.
Related Models
Magic Chef 22FA-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FA-6CKLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22FA-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FA-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FK-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FK-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FK-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FN-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FN-6CKLXV8 MAGIC CHEF COOKING
Magic Chef 22FN-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FN-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22FY-2KLW RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FY-2KW WALLOVEN-STD DBL OVEN GAS
Magic Chef 22FY-6KLX RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FY-6KLX-6F RANGE- CONT CLEAN DBL OVEN GAS
Magic Chef 22FY-6KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JA-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JK-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JN-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22JY-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22M-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22MA-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22MN-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22MW-7KLXV8 RANGE- CONT CLEAN MWAVE GAS
Magic Chef 22RA-3B-49 RV RANGE- GAS
Magic Chef 22RA-3BKZ RV RANGE- GAS
Magic Chef 22RA-3BTZ RV RANGE- GAS
Magic Chef 22RA-3BZ RV RANGE- GAS
Magic Chef 22RA-4 RV RANGE- GAS
Magic Chef 22RA-4K RV RANGE- GAS
Magic Chef 22RA-4K-49 RV RANGE- GAS
Magic Chef 22RA-4KVX RV RANGE- GAS
Magic Chef 22RA-4KX RV RANGE- GAS
Magic Chef 22RA-4KZ RV RANGE- GAS
Magic Chef 22RA-4T RV RANGE- GAS
Magic Chef 22RA-4TVX RV RANGE- GAS
Magic Chef 22RA-4TX RV RANGE- GAS
Magic Chef 22RA-4TZ RV RANGE- GAS
Magic Chef 22RB-3B RV RANGE- GAS
Magic Chef 22RB-3BKZ RV RANGE- GAS
Magic Chef 22RB-3BTVX RV RANGE- GAS
Magic Chef 22RB-3BTZ RV RANGE- GAS
Magic Chef 22RB-3BZ RV RANGE- GAS
Magic Chef 22RB-4K RV RANGE- GAS
Magic Chef 22RB-4KX RV RANGE- GAS
Magic Chef 22RB-4KZ RV RANGE- GAS
Magic Chef 22RB-4T RV RANGE- GAS
Magic Chef 22RB-4TX RV RANGE- GAS
Magic Chef 22RB-4TZ RV RANGE- GAS
Magic Chef 22RS-4KVX RV RANGE- GAS
Magic Chef 22RS-4KX RV RANGE- GAS
Magic Chef 22RS-4KZ RV RANGE- GAS
Magic Chef 22RS-4TVX RV RANGE- GAS
Magic Chef 22RS-4TX RV RANGE- GAS
Magic Chef 22RS-4TZ RV RANGE- GAS
Magic Chef 22RW-3B-49 RV RANGE- GAS
Magic Chef 22RW-3BK RV RANGE- GAS
Magic Chef 22RW-3BK49 RV RANGE- GAS
Magic Chef 22RW-3BKZ RV RANGE- GAS
Magic Chef 22RW-3BTVX RV RANGE- GAS
Magic Chef 22RW-3BTZ RV RANGE- GAS
Magic Chef 22RW-3BZ RV RANGE- GAS
Magic Chef 22RW-4 RV RANGE- GAS
Magic Chef 22RW-4K RV RANGE- GAS
Magic Chef 22RW-4K-49 RV RANGE- GAS
Magic Chef 22RW-4KX RV RANGE- GAS
Magic Chef 22RW-4KZ RV RANGE- GAS
Magic Chef 22RW-4T RV RANGE- GAS
Magic Chef 22RW-4TX RV RANGE- GAS
Magic Chef 22RW-4TZ RV RANGE- GAS
Magic Chef 22TA-3BKZ RV RANGE- GAS
Magic Chef 22TA-3BZ RV RANGE- GAS
Magic Chef 22TA-4-49 RV RANGE- GAS
Magic Chef 22TA-4KZ RV RANGE- GAS
Magic Chef 22TA-4Z RV RANGE- GAS
Magic Chef 22TB-3B RV RANGE- GAS
Magic Chef 22TB-3BKZ RV RANGE- GAS
Magic Chef 22TB-3BZ RV RANGE- GAS
Magic Chef 22TW-3B-49 RV RANGE- GAS
Magic Chef 22TW-3BK RV RANGE- GAS
Magic Chef 22TW-3BK49 RV RANGE- GAS
Magic Chef 22TW-3BKE RV RANGE- GAS
Magic Chef 22TW-3BKZ RV RANGE- GAS
Magic Chef 22TW-3BZ RV RANGE- GAS
Magic Chef 22TW-4KZ RV RANGE- GAS
Jenn-Air 2300 SURFACE UNIT- DDRAFT ELE
Jenn-Air 2300ERS SURFACE UNIT- DDRAFT ELE
Jenn-Air 2320ERS SURFACE UNIT- DDRAFT ELE
Roper 2323*0A Ranges, Electric*
Roper 2323W0A Ranges, Electric*
Roper 2324W0A Ranges, Electric*
Jenn-Air 2325ERS SURFACE UNIT- DDRAFT ELE
Roper 2326*0A Ranges, Electric*
Roper 2326W0A Ranges, Electric*
Kenmore 23310428 RANGE HOOD
Kenmore 23310442 RANGE HOOD
Kenmore 23334201 RANGE HOOD
Kenmore 23334202 RANGE HOOD
Kenmore 23334203 RANGE HOOD
Kenmore 23334204 RANGE HOOD
Kenmore 23334311 RANGE HOOD
Kenmore 23334319 RANGE HOOD
Kenmore 23350303200 RANGE HOOD
Kenmore 23350363200 RANGE HOOD
Kenmore 23350941590 RANGE HOOD
Kenmore 23350944590 RANGE HOOD
Kenmore 23350949590 RANGE HOOD
Kenmore 23351003600 RANGE HOOD
Kenmore 23351040590 RANGE HOOD
Kenmore 23351041590 RANGE HOOD
Kenmore 23351044590 RANGE HOOD
Kenmore 23351049590 RANGE HOOD
Kenmore 23351063600 RANGE HOOD
Kenmore 2335108010 KENMORE RANGE HOOD
  #2 (permalink)
Old 11-25-2008, 11:51 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
The noise you're describing points to the motor coupler. When the machine is overloaded, the coupler will break, separating the motor from the transmission, to prevent expensive damage. It is relatively easy to replace.
  #3 (permalink)
Old 11-25-2008, 02:52 PM
Junior Member
Default
what is the procedure to repair it? do you access it from the agitator, or from the back? How can i confirm that is my problem?
Last edited by bec777@charter.net : 11-25-2008 at 02:59 PM. Reason: i didn't read the answer correctly and need to ask a better question
  #4 (permalink)
Old 11-25-2008, 04:10 PM
Senior Expert
APP Volunteer
Default
Everything mechanical is accessed through the front of the machine. The entire cabinet comes off. First, unplug the machine. Next, pull the end caps off the console. This exposes two screwa on the front of the console, one at each corner. Remove the screws and the console will pull slightly forward, and swing up on its hinges. You will then notice a plastic connector about center. Separate it. This is your lid switch connector.
The next thing you'll see is wavy spring clips (usually brass plated, but often dingy or rusted with age). Applying a downward and forward pressure on them with a screwdriver will pop them out of the slots on the cabinet. They hook into the back panel.
With the clips off, you can now rock the cabinet forward and off the chassis and move it out of the way. It weighs maybe 40 pounds; awkward to handle. Bottom center is the motor/pump assembly. The pump is clipped top and bottom to the motor. No need to disconnect hoses; just remove the clips and move the pump out of the way. Next, same types of clips on the motor. They're generally screwed to the motor with 5/16 inch hex drive screws. Remove the bottom one first. The motor is deceptively heavy. The coupler is a three piece assembly. Removal and reinstallation is self-evident, but takes patience.
The reassembly is just the reverse of this procedure. The hardest parts are lining up the motoe and coupler when reinstallng them; and making sure the cabinet sits properly on the alignment tabs on the chassis.
Let me know how it goes.
  #5 (permalink)
Old 01-25-2009, 02:21 PM
Junior Member
ericburnley is on a distinguished road
Default
I just wanted to come back and say THANK YOU to magician59. I had this exact issue occur with our Kenmore washer, and your instructions were concise, easy to follow, and exactly what I needed. This fix cost me a total of $5.50 (incl shipping).
The only issue I had was that one of the new metal center coupler pieces was a bit tight for the washer's shaft, so I ended up leaving the unbroken original coupler piece with the plastic center in place for now. I got the one for the motor in place by tapping it with the handle of a screwdriver, but the washer's shaft was a bit more difficult to reach. If (or when) the plastic one breaks, I can figure out how to get the new piece in place. At the time, it had been a very long day and we had a large amount of laundry to get to.
Thanks again!
  #6 (permalink)
Old 04-19-2009, 10:31 PM
Junior Member
bigmac1465 is on a distinguished road
Default
Kudos to "magician59"!
I just followed the instruction to the last dot and the washer is working again.
I too ran into the same problem "ericburnley" did and ended up replacing only the broken piece because of the shaft tightness issue.
Thank you very much.
  #7 (permalink)
Old 04-20-2009, 05:29 AM
Senior Expert
APP Volunteer
Default
So glad to know you were able to fix it
1 Thanks for the feedback. It is comforting to hear that an instruction or a tip offered was both understood AND helpful.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore series 70 washer will not agitate or spin have not found answer in other post industrial_elec Washer Repair 1 08-06-2012 03:21 PM
Kenmore 80 Series Won't Agitate Will Spin meganandkids Washer Repair 5 01-08-2010 02:32 PM
kenmore 70 series washer will not agitate/spin + rusty drive shaft/pump pkme Washer Repair 2 01-27-2009 07:55 AM
kenmore elite 90 series won't agitate or spin compton Washer Repair 4 12-15-2008 06:00 PM
Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise Scottmcc Washer Repair 6 01-05-2008 07:24 AM
